BT.com
Wishlist
Sony VPL-MX20 LCD XGA Projector - 2500 ANSI Lumens
Delivery
Standard Due date unavailable
When you've only got a short opportunity to impress your audience, you want to be in complete control. This stylish projector has been designed to be exceptionally portable. Lightweight and slim with a contemporary ergonomic design it is the ultimate personal projector for business professionals striving to create an impact with their presentations. With a depth of 45mm and weight of only 1.7 kg, it is lightweight and easy to carry. The projector's five step advanced intelligent auto set up feature means it is quick and simple to operate. In addition, the off-and-go function means it can be unplugged immediately after being switched off.
By combining an optical system that incorporates Sony's innovative BrightEra with Long Lasting Optics technology and a 3LCD projection system, the VPL-MX20 delivers high picture quality in XGA (1024 x 768) resolution and a high brightness of 2500 lumens. This allows professional presentations to be delivered in virtually any presentation environment.
Sony VPL-MX20 - LCD projector
LCD projector
Black, silver
Brightness
2500 lumens
Brightness (Colour)
2500 lumens
Contrast Ratio
650:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Bulb type
UHP 200 Watt
Bulb life cycle
Up to 2000 hour(s) / up to 3000 hour(s) (economic mode)
Video Input
RGB, composite video, component video (SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58)
Video Modes
575/50i, 575/50p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 480/60i
290 Watt
27.3 cm x 20.6 cm x 4.5 cm
1.7 kg
3 years warranty
LCD projector
Enclosure Colour
Black, silver
Projector
Brightness
2500 lumens
Brightness (Colour)
2500 lumens
Brightness (Reduced)
2000 lumens
Contrast Ratio
650:1
Image Size
76 cm - 381 cm
Digital Zoom Factor
4x
Resolution
XGA - XGA (1024 x 768) (native) / 1400 x 1050 (resized)
Native Aspect Ratio
4:3
Display Format
2,359,296 pixels (1024 x 768)
Max Sync Rate (V x H)
92 Hz x 80 Hz
Bulb type
UHP 200 Watt
Bulb life cycle
BrightEra
Lens
Lens Aperture
F/1.65-1.8
Zoom Type
Powered
Zoom Factor
1.2x
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, composite video
Video Modes
Input Device
External
1 x composite video input - RCA , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15)
Carrying case, wireless remote control
1 x VGA cable - 2 m
Security Features
Control panel lock
FCC Class B certified, IC Class B, CSA, VCCI, C-Tick, cUL, DEMKO, CB, EMC, EK, IEC 60950-1, EN 60950-1, JEITA
Nominal Voltage
290 Watt
27.3 cm
20.6 cm
4.5 cm
1.7 kg
Limited warranty - 3 years - pick-up and return , Technical support - phone consulting - 3 years
35 °C
35 - 85%
Sound Emission
38 dB
Accessories
Sony Lamp Module for VPL-MX20/MX25
Quicklinx: 6ZMC | In Stock
£343.78
Scroll to top
