BT.com
Wishlist
Sony VPL-EX295 XGA LCD 3800 Lumens Projector
Delivery
Standard Due date unavailable
Combining superb XGA image quality with smart energy-efficient features, the VPL-EX295 portable projector enhances learning with powerful presentations that really stand out. Simple to use and wireless ready, the projector is ideal for maximizing student engagement in today's networked classrooms, making it your ideal partner throughout the busy school day.
Sony BrightEra panel technology assures clear pictures in any conditions, from daylight to darkened classrooms. Plenty of interfaces allow easy connection, while a choice of picture modes optimizes viewing with any source - slide presentations, PC documents, pictures or videos. There's a wide range of smart energy-saving features built in.
Sony VPL-EX295 - 3LCD projector
3LCD projector
Built-in Devices
Speaker
Brightness
3800 lumens
Brightness (Colour)
3800 lumens
Contrast Ratio
3300:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Bulb type
Ultra high-pressure mercury 210 Watt
Bulb life cycle
Up to 4000 hour(s) / up to 10000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, NTSC 3.58)
Video Modes
575/50p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
Speakers
Speaker(s) - integrated
299 Watt
36.5 cm x 25.2 cm x 9.62 cm
4 kg
3LCD projector
Built-in Devices
Speaker
Ethernet
Projector
Brightness
3800 lumens
Brightness (Colour)
3800 lumens
Brightness (Reduced)
2100 lumens
Contrast Ratio
3300:1
Image Size
0.76 m - 7.62 m
Throw Ratio
1.4 - 2.27:1
Resolution
XGA - XGA (1024 x 768) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
4:3
Display Format
2,359,296 pixels (1024 x 768) x 3
Max Sync Rate (V x H)
93 Hz x 93 kHz
Bulb type
Bulb life cycle
OSD Languages
Hungarian, Indonesian, Thai, Chinese (traditional), Chinese (simplified), Vietnamese, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Japanese, Korean
High-bandwidth Digital Content Protection System (HDCP), 3LCD Technology, BrightEra
Lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
1.6x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-30 / +30
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video, S-Video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
Speakers
1 x mixed channel
2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x HDMI - 19 pin HDMI Type A , 1 x S-video input - 4 pin mini-DIN , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 (management) , 1 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B , 1 x microphone input - mini-phone stereo 3.5 mm , 1 x audio line-in - RCA x 2 , 2 x audio line-in - mini-phone stereo 3.5 mm
Remote control, lithium coin cell battery
1 x VGA cable
Nominal Voltage
299 Watt
Power Consumption Stand by
5.1 Watt
36.5 cm
25.2 cm
9.62 cm
4 kg
35 - 85% (non-condensing)
Accessories
£9.99
£6.91
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£18.84
£36.18
£49.00
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£55.62
Scroll to top
