BT.com
Wishlist
Sony VPL-EX255 WXGA LCD 3300 Lumenns Projector
Delivery
Standard Due date unavailable
Combining superb XGA image quality with smart energy-efficient features, the VPL-EX255 portable projector enhances learning with powerful presentations that really stand out. Simple to use and wireless ready, the projector is ideal for maximizing student engagement in today's networked classrooms, making it your ideal partner throughout the busy school day.
Sony BrightEra panel technology assures clear pictures in any conditions, from daylight to darkened classrooms. Plenty of interfaces allow easy connection, while a choice of Picture Modes optimizes viewing with any source - slide presentations, PC documents, pictures or videos. Adding an optional Wi-Fi module lets students and teachers wirelessly share homework, images and graphics from mobile devices like smartphones and tablets. There's a wide range of smart energy-saving features built in.
Sony VPL-EX255 - 3LCD projector
3LCD projector
Built-in Devices
Speaker
Brightness
3300 lumens
Contrast Ratio
3300:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Bulb type
Ultra high-pressure mercury 210 Watt
Bulb life cycle
Up to 3000 hour(s) / up to 10000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video, component video (SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, NTSC 3.58)
Video Modes
1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
Speakers
Speaker(s) - integrated
301 Watt
36.5 cm x 25.2 cm x 9.62 cm
4 kg
3LCD projector
Built-in Devices
Speaker
Ethernet
Projector
Brightness
3300 lumens
Brightness (Reduced)
1700 lumens
Contrast Ratio
3300:1
Image Size
76.2 cm - 762 cm
Throw Ratio
1.4 - 2.27:1
Resolution
XGA - XGA (1024 x 768) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
4:3
Max Sync Rate (V x H)
93 Hz x 93 kHz
Bulb type
Bulb life cycle
Controls & Adjustments
Keystone correction
3LCD Technology, BrightEra, Automatic Brightness Adjustment, Auto Lamp Dimming Function
Lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
1.6x
Keystone Correction Direction
Horizontal
Horizontal Keystone Correction
-30 / +30
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
Speakers
1 x mixed channel
1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x HDMI input - 19 pin HDMI Type A , 1 x network - RJ-45 , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C - 9 pin D-Sub (DB-9) , 1 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - RCA x 2
Power Source
AC
Nominal Voltage
301 Watt
Power Consumption Stand by
0.5 Watt
36.5 cm
25.2 cm
9.62 cm
4 kg
35 - 85% (non-condensing)
Accessories
£9.99
£6.94
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£18.78
£36.49
£49.42
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£56.07
Scroll to top
