Click to visit BT.com
BT.com
Wishlist
Sony VPL-DX11 XGA Projector
Quicklinx: 5K7YWS00
Mfr#: VPL-DX11
The VPL-DX11 is a compact and portable projector which is simple to operate. This projector weighs light and has a footprint smaller than an A4 sheet of paper. This means it can be easily and quickly carried between meetings, and is ideal for small- to medium-sized rooms including corporate conference rooms and school classrooms.
By combining an optical system that incorporates Sony's innovative BrightEra technology and a 3LCD projection system, the VPL-DX11 delivers high picture quality in XGA resolution and a high brightness of 3000 lumens. This allows professional presentations to be delivered in virtually any setting and under any lighting conditions.
Features include an easy-to-use control panel with all essential controls arranged together on the top of the unit, 'Off and Go' so there is no need to wait for fans to turn off before unplugging from mains power, and 'Quick Re-start' so that it is ready to present again within 5 seconds of an accidental power-down.
Sony VPL-DX11 LCD projector
LCD projector
Built-in Devices
Speaker
Brightness
3000 lumens
Brightness (Colour)
3000 lumens
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Bulb type
UHP 200 Watt
Bulb life cycle
Up to 2400 hour(s) / up to 3000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video, component video ( SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58 )
Video Modes
575/50i, 575/50p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 480/60i
Speakers
Speaker(s) - integrated
AC 120/230 V ( 50/60 Hz )
320 Watt
29.5 cm x 20.4 cm x 7.4 cm
2.1 kg
LCD projector
Built-in Devices
Speaker
Projector
Brightness
3000 lumens
Brightness (Colour)
3000 lumens
Brightness (Reduced)
2400 lumens
Image Size
102 cm - 762 cm
Digital Zoom Factor
4x
Resolution
XGA - XGA (1024 x 768)
Native Aspect Ratio
4:3
Display Format
2,359,296 pixels (1024 x 768)
Max Sync Rate (V x H)
92 Hz x 80 kHz
Bulb type
UHP 200 Watt
Bulb life cycle
Freeze frame, Picture Muting, BrightEra
Lens
Lens Aperture
F/1.65-1.8
Zoom Type
Powered
Zoom Factor
1.2x
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, composite video, S-Video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
1 Watt
Speakers
1 x mixed channel
Input Device
External
1 x S-video input - 4 PIN mini-DIN , 1 x composite video input - RCA , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - mini-phone stereo 3.5 mm
Carrying case, wireless remote control
1 x VGA cable - 2 m
Security Features
Security lock slot (cable lock sold separately), password protection, control panel lock, security label
Nominal Voltage
320 Watt
Power Consumption Operational ( Standby )
3 Watt
29.5 cm
20.4 cm
7.4 cm
2.1 kg
35 °C
35 - 85%
