BT.com
Wishlist
Sony SAL1650 16-50mm f/2.8 Zoom Lens A Mount for Alpha
Sony SAL1650 16-50mm f/2.8 Zoom...
£648.96
£648.96
Add to wishlist
Delivery
Standard Due date unavailable
SAL1650 is a high quality standard telephoto lens, ideal for wide range of everyday applications, including portraits, travel, landscapes and general-purpose shooting. Bright F2.8 maximum aperture allows creation of smooth background defocus effects (bokeh). High performance optics achieve versatile zoom range in light, easy-to-carry lens body. Internal SSM (Super Sonic wave Motor) drive achieves exceptionally fast, quiet autofocus - ideal for stills and HD movie shooting. Aspherical lens elements and ED glass elements suppress aspheric and chromatic aberration for superb resolution and contrast. Rugged weather-resistant design with interlocking seals protects against effects of dust and moisture.
Sony SAL1650 - zoom lens - 16 mm - 50 mm
Lens System
Zoom lens
Intended For
Digital SLR
Mounting Type
Sony A-type
Lens Aperture
F/2.8
Focal Length
16 mm - 50 mm
Optical Zoom
3 x
Min Focus Distance
30 cm
Focus Adjustment
Automatic, manual
Lens Construction
13 groups / 16 elements
Special Functions
Zoom
Filter Size
72 mm
Length
8.8 cm
0.58 kg
? SLT-A57, SLT-A57K, SLT-A57M, SLT-A57Y, SLT-A58K, SLT-A58M, SLT-A58Y, SLT-A65, SLT-A65VK, SLT-A65VL, SLT-A65VM, SLT-A65VY; a58 SLT-A58
Length
8.8 cm
Diameter
8.1 cm
0.58 kg
Lens System
Zoom lens
Special Functions
Zoom
Intended For
Digital SLR
Focal Length
16 mm - 50 mm
Lens Aperture
F/2.8
Minimum Aperture
F/22
Focal Length Equivalent to 35mm Camera
24 - 75mm
Optical Zoom
3 x
Magnification
0.2
Min Focus Distance
30 cm
Focus Adjustment
Automatic, manual
Zoom Adjustment
Manual
Max View Angle
83 degree(s)
Min View Angle
32 degree(s)
Lens Construction
Filter Size
72 mm
Diaphragm Blades
7
Mounting Type
Sony A-type
ED glass, aspherical lens, Supersonic-Wave Motor (SSM), dustproof, weatherproof
Lens hood, dust cap, lens cap
Sony a SLT-A57, SLT-A57K, SLT-A57M, SLT-A57Y, SLT-A58K, SLT-A58M, SLT-A58Y, SLT-A65, SLT-A65VK, SLT-A65VL, SLT-A65VM, SLT-A65VY , Sony a58 SLT-A58
Scroll to top
