Click to visit BT.com
BT.com
Wishlist
Sony NWZ-W273 Walkman® 4GB waterproof MP3 player - Black
Quicklinx: 8NLDWS00
Mfr#: NWZW273B.CEW
NWZ-W273 Walkman® waterproof MP3 player
Made to move
4GB MP3 player with waterproof, wire-free design, 8 hour playback and quick charge
  • 100% waterproof for swimming, sweat or rain
  • Designed to stay in-ear when action's fast or wet
  • Drag and drop songs from your music library
  • Mix it up in the pool - Enjoy your favourite tunes when you're taking a swim, the NWZ-W273 is 100% waterproof up to 2 metres (IPX8 rated) - For use in swimming pools, various sizes of ear-buds are supplied with this model. Correct sound volume can be maintained in water by using the most appropriate ear-bud size to ensure there is no gap allowing water into the ear. Time to get flexible - There are no wires, so you can really free up your movement when you're training
  • Ready for anything - Get a secure in-ear fit, the NWZ-W273 won't fall off when you're jogging, swimming or even rowing
  • Don't get weighed down - You'll hardly notice the NWZ-W273 is there thanks to a light and compact design
  • Create a pumping playlist - It's simple, just drag and drop your favourite workout music from iTunes™ or Windows® Explorer and you're ready to go
  • Quick charge and go - A 3 minute power up gives 60 minutes of listening time, pop it on while you change your gear
  • Move to the beat with 13.5mm EX Series headphones - Get inspiration from every uplifting chorus with a wide sound range of 20 to 20,000 Hz, for detailed audio whatever the volume
  • Get your pulse racing with ZAPPIN™ - Hear a flash of a song's chorus before playing the track in its entirety; you can quickly find a beat that helps you pick up the pace
  • Go the whole distance - With a full charge you get 8 hours' playback**, it's all the music you need for long training sessions
  • Big storage with 4GB memory - From thumping tunes to relaxing warm-down tracks, you can store 990*** songs and always have the right music whatever the workout
  • Jog friendly music - Use the jog lever to easily skip through music folders on the go in one fluid movement
  • Customise your fit - With two sizes of ear buds supplied and an adjustable band, you can find the most comfortable fit for you
It's really this simple:
Sony Walkman NWZ-W273 - digital player
Digital player flash based
Enclosure Colour
29 g
Playback Digital Standards
WMA, MP3, AAC-LC, LPCM
Sound Output Mode
Stereo
Flash Memory
4 GB
Headphones
Headphones - binaural - in-ear (with behind-the-neck mount) - stereo
Interface Supported
USB
Player rechargeable
Digital player
Digital Player Type
Flash based
29 g
Enclosure Colour
Interface Supported
USB
Supported Digital Audio Standards
Audio System
Flash Memory
4 GB
Sound Output Mode
Stereo
Water Resistant
ZAPPIN technology, washable, waterproof
Headphones
Headphones Type
Sound Output Mode
Stereo
Frequency Response
20 - 20000 Hz
USB cable, 2 pairs of ear tips (small, large)
Player rechargeable
Battery Enclosure Type
Integrated
Run Time (Up To)
8 hour(s)
Recharge Time
1.5 hour(s)
Additional Requirements
USB port
