BT.com
Wishlist
Sony KDL43WD751BU 43" 1920 x 1080 HDMI USB HD LED Television
Sony KDL43WD751BU 43" 1920 x 1080...
£414.40
£414.40
Add to wishlist
Delivery
Standard Due date unavailable
Marketing description is not available.
Sony KDL-43WD751 BRAVIA WD751 Series - 43" LED TV
LED-backlit LCD TV
Diagonal Class
43"
Black aluminium bezel
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
480/60p, 720/60p, 720/50p, 576/50p, 480/60i, 576/50i, 720/24p, 720/30p
Motion Enhancement Technology
Motionflow XR 200 technology, 50 Hz Refresh Rate
24p Technology
24p True Cinema
Video Interface
HDMI, SCART
HDMI Ports Qty
2 ports
Wi-Fi, LAN
LCD Backlight Technology
LED backlight - edge-lit
Image Aspect Ratio
16:9
TV Tuner
1x analogue, 1x digital
Digital TV Tuner
DVB-C, DVB-T, DVB-T2
Internet Streaming Services
YouTube
Speaker System
2 speakers
USB
2 ports
Remote Control
Standard remote
Energy Class
Class A+
74 Watt
Power Consumption (On mode)
53 W
Energy Consumption per Year
77 kWh
96 cm x 5.6 cm x 56.5 cm
9.1 kg
LED-backlit LCD TV
Energy Class
Class A+
74 Watt
53 W
77 kWh
Diagonal Class
43"
Series
BRAVIA WD751 Series
TV Tuner
Extended PVR
Video Interface
HDMI, SCART
HDMI Ports Qty
2 ports
Modes
Game mode, Film Mode, backlight off mode, Sports mode, Cinema mode
Dimensions
Without stand
96 cm
5.6 cm
56.5 cm
9.1 kg
Enclosure Colour
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
24p Technology
24p True Cinema
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Display Menu Language
Multilingual
Advanced Contrast Enhancer circuit (ACE), X-Reality PRO Engine, CineMotion, Cinema Drive, Dynamic Backlight Control
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Stand Colour
Silver
Flat Panel Mount Interface
TV Tuner
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
Digital TV Tuner
Video Features
Input Video Formats
Electronic Programme Guide
Digital EPG
Parental Channel Lock
Media Player
USB Port
USB Ports Qty
2
Remote Control
Standard remote
Remote Control Model
Sony RMT-TX102D
Scene Select
Audio System
Digital Audio Format
Dolby Digital output, Dolby Digital Plus output, Dolby Pulse output
Speaker System
2 speakers
Output Power / Total
20 Watt
S-Master Digital Amplifier, Clear Phase Speaker
Speakers
2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
Functionality
Digital audio playback, digital photo playback, digital video playback, Internet video playback
Wi-Fi, LAN
Connect & Share
Wi-Fi Direct, Screen Mirroring, Home Network Sharing
YouTube
Supported Consumer Electronics Control (CEC)
BRAVIA Sync Function
Connector Type
2 x USB - side , HDMI input - rear , Audio line-out / headphones / subwoofer - side , SPDIF output - rear , Network - rear , SCART , HDMI input - side
Batteries
Power supply
Power Consumption Stand by
0.5 Watt
On/off timer
Dimensions & Weight Details
Panel without stand - 96 cm x 5.6 cm x 56.5 cm x 9.1 kg , Panel with stand - 96 cm x 22.9 cm x 61.6 cm x 9.8 kg
Width (Shipping)
105.8 cm
Depth (Shipping)
16.3 cm
Height (Shipping)
66.9 cm
Cables
Sony KDL43WD751BU 43" 1920 x 1080 HDMI USB HD LED...
£414.40
Save on HDMI Cable when you buy this TV
£424.39
Accessories
£414.40
Essential TV Accessory
£439.39
Scroll to top
