BT.com
Wishlist
Sony KDL40RD453BU 40" 1920 x 1080 HDMI USB HD LED Television
Sony KDL40RD453BU 40" 1920 x 1080...
£349.99
More than 50 in stock
£349.99
Add to wishlist
Delivery
Standard 1-3 working days
High Definition with extra brilliance
Experience our stunning Full HD picture quality, whatever you're watching. Sony's unique X-Reality PRO processing engine analyses, cleans and refines images for beautifully detailed viewing.
X-Reality PRO: Rediscover every detail
Discover a thrilling world of extraordinary clarity, whatever you're watching. Every single pixel is upscaled beautifully by our powerful picture processing engine, while individual parts of each scene are analysed and matched with a special image database that independently addresses texture, contrast, colour and edges. Enjoy dramatically reduced picture noise, whatever you're watching.
Full HD 1080p
Experience the detail of Full HD 1080p across all your entertainment. From Blu-ray Discs to catch-up TV to smartphone photos, you can see it all in perfect clarity on the big screen with this Bravia TV.
Motionflow XR keeps the action smooth
Enjoy smooth and sharp details even in fast-moving sequences with Motionflow XR. This innovative technology creates and inserts extra frames between the original ones. It compares key visual factors on successive frames, then calculates the split second of missing action in the sequences. Some models also include black-frame insertion for a blur-free and truly cinematic look.
Super multi-format USB play
Enjoy your favourite digital content from any USB stick. Play music, video clips and view photo collections all through your TV with super multi-format USB play. Supporting a wide range of codecs, you can experience ultimate format versatility, simply plug in and you're ready to go.
Slim look
The screen has a narrow frame, accented with minimal bezels, so you can focus on your entertainment with near edge-to-edge pictures.
Clear Phase for smooth, balanced frequencies
BRAVIA uses a powerful computer model to analyse and compensate for inaccuracies in speaker response. It does this by 'sampling' the speaker frequency with higher precision. This information is fed back to cancel out any peaks or dips in the speaker's natural response - resulting in pure, natural audio with smooth, even reproduction of all frequencies.
Cable management
Keep wires out of sight. All of your cables can be neatly arranged across the back of the TV and channelled into the stand, so everything looks tidy.
Listen to your photos with Photo Frame Mode
Turn your TV into a super-size photo frame. Connect to your personal device and enjoy your photo collection with a choice of attractive slideshow, clock and calendar display modes plus a wake-up timer. Add a soundtrack with the radio or your own stored music tracks.
Turn your TV into a digital recorder: USB HDD REC
Store your favourite TV shows on an external USB hard disk drive to enjoy whenever you want. USB HDD REC allows one-touch and timer recording of a digital broadcast onto any USB HDD device up to 2 TB in capacity. While viewing the show, simply press REC to start recording, which will automatically stop at the end of the programme.
Sony KDL-40RD453 BRAVIA RD453 Series - 40" LED TV
LED-backlit LCD TV
Energy Class
Class A+
59.4 Watt
Power Consumption (On mode)
48 W
Energy Consumption per Year
70 kWh
Diagonal Class
40"
Series
BRAVIA RD453 Series
TV Tuner
1x analogue, 1x digital
Video Interface
HDMI, SCART
HDMI Ports Qty
2 ports
Modes
Film Mode, backlight off mode, Photo Frame mode
Dimensions
Without stand
92.4 cm
6.6 cm
54.9 cm
7.7 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Motion Enhancement Technology
Motionflow XR 200 technology, 50 Hz Refresh Rate
24p Technology
24p True Cinema
LCD Backlight Technology
LED backlight - direct-lit LED
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Advanced Contrast Enhancer circuit (ACE), X-Reality PRO Engine, CineMotion, Cinema Drive, Dynamic Backlight Control
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Stand Colour
Flat Panel Mount Interface
TV Tuner
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
Digital TV Tuner
DVB-C, DVB-T, DVB-T2
Video Features
Input Video Formats
1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 480/60i, 576/50i
Parental Channel Lock
Media Player
USB Port
USB Ports Qty
2
Remote Control
Standard remote
Remote Control Model
Sony RM-ED062
Scene Select
Audio System
Digital Audio Format
Dolby Digital output, Dolby Digital Plus output, Dolby Pulse output
Speaker System
2 speakers
Output Power / Total
10 Watt
S-Master Digital Amplifier, Clear Phase Speaker
Speakers
2 x main channel speaker - built-in - 5 Watt
Network & Internet Multimedia
Supported Consumer Electronics Control (CEC)
BRAVIA Sync Function
Connector Type
SCART - rear , HDMI input - rear , HDMI input - side , Audio line-in - rear , SPDIF output - rear , Audio line-out / headphones / subwoofer - side , 2 x USB - side
Batteries
Power adapter
Power Consumption Stand by
0.5 Watt
On/off timer
Dimensions & Weight Details
Panel without stand - 92.4 cm x 6.6 cm x 54.9 cm x 7.7 kg , Panel with stand - 92.4 cm x 21.2 cm x 58.9 cm x 8.1 kg
Width (Shipping)
101.5 cm
Depth (Shipping)
16.1 cm
Height (Shipping)
65.8 cm
Accessories
Sony KDL40RD453BU 40" 1920 x 1080 HDMI USB HD LED...
£349.99
Essential TV Accessory
£374.98
Scroll to top
