BT.com
Wishlist
Sony KDL32R423ABU 32 inch LCD TV Blk 100Hz HD Ready 2 HDMI
Delivery
Standard Due date unavailable
Bring your entertainment to life
Enjoy a more rewarding entertainment experience with the HD Ready R42. It features a suite of picture-enhancing technologies designed to capture your imagination with pure, detailed images, smooth action sequences and deep, sumptuous contrast.
Heighten the detail, heighten the drama
Take Full HD detail a step further with Clear Resolution Enhancer - a noise reduction and image enhancement technology that delivers a clear difference from standard LED TV. Images are crisp, textures are defined, and heightened contrast boosts on-screen depth perception.
Movement looks smoother and more natural
At the height of the drama, when you're at the edge of your seat, Motionflow XR 100Hz ensures fast-moving action sequences appear smooth, natural and lifelike. It even offers a choice of viewing modes to suit different content - from movies to sport or live entertainment.
Vivid, true-to-life colour and contrast
Rich, natural colour makes the images you see more compelling and believable. With Direct LED backlight screen technology you'll enjoy pure colours, high contrast and deep blacks. It ensures an altogether more vivid viewing experience - and it's energy efficient too.
Mirror your mobile content on your TV
Super-size your pictures, videos, apps, games and more with wired mirroring. Just connect your smartphone to the TV through the USB port and view your mobile content on your TV. Use your smartphone to swipe, enlarge, move and select content on the big screen for all to see.
Sony KDL-32R423A BRAVIA R42 Series - 32" LED TV
LED-backlit LCD TV
Diagonal Class
32"
Resolution
1366 x 768
Display Format
720p
Input Video Formats
1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
Motion Enhancement Technology
Motionflow XR 100 technology
24p Technology
24p True Cinema
Video Interface
Component, composite, HDMI, SCART
HDMI Ports Qty
2 ports
HDCP Compatible
LCD Backlight Technology
LED backlight - direct-lit LED
Image Aspect Ratio
16:9
Digital TV Tuner
DVB-C, DVB-T2
Speaker System
2 speakers
Stereo Reception System
NICAM, A2
USB
Remote Control
Standard remote
Energy Class
Class A
58 Watt
Power Consumption (On mode)
40 W
Energy Consumption per Year
58 kWh
73.1 cm x 17.1 cm x 46.6 cm
5.3 kg
LED-backlit LCD TV
Energy Class
Class A
58 Watt
40 W
58 kWh
Diagonal Class
32"
Series
BRAVIA R42 Series
Video Interface
HDMI Ports Qty
2 ports
HDCP Compatible
Modes
Photo Frame mode
Timer Functions
Sleep, wake
Dimensions
With stand
73.1 cm
17.1 cm
46.6 cm
5.3 kg
Display
Resolution
1366 x 768
Display Format
720p
Image Aspect Ratio
16:9
24p Technology
24p True Cinema
Widescreen Modes
Zoom 14:9, Auto Wide, Full, Wide Zoom, Zoom, Normal, Caption
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Advanced Contrast Enhancer circuit (ACE), Live Color, Clear Resolution Enhancer, CineMotion, Cinema Drive
Stands & Mounts
Stand
Included
Stand Design
Tabletop
TV Tuner
Conditional Access
Common Interface Plus (CI+) slot
NICAM, A2
Digital TV Tuner
Digital TV Tuner
DVB-C, DVB-T2
Video Features
Input Video Formats
Electronic Programme Guide
Digital EPG
Parental Channel Lock
Media Player
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Remote Control Model
Sony RM-ED054
Scene Select
Audio System
Digital Audio Format
Dolby Digital Plus output, Dolby Pulse output
Audio Controls
Sound mode
Speaker System
2 speakers
Output Power / Total
16 Watt
Speakers
2 x main channel speaker - built-in - 8 Watt
Network & Internet Multimedia
Connect & Share
Mobile High-Definition Link (MHL)
Supported Consumer Electronics Control (CEC)
BRAVIA Sync Function
Connector Type
HDMI input - rear , HDMI input - side , 2 x SCART - rear , USB - side , Composite video / component video input - rear , Audio line-in - rear , Digital audio output (optical) - rear , Audio line-out / headphones - rear
2 AAA batteries
Power supply
Power Consumption Stand by
0.5 Watt
Dimensions & Weight Details
Panel without stand - 73.1 cm x 7.6 cm x 44.1 cm x 5.1 kg , Panel with stand - 73.1 cm x 17.1 cm x 46.6 cm x 5.3 kg
Width (Shipping)
87.6 cm
Depth (Shipping)
14.9 cm
Height (Shipping)
50.8 cm
Scroll to top
