Click to visit BT.com
BT.com
Wishlist
Sony FWD-32B1 32" Full HD DVI HDMI CCFL Monitor
Quicklinx: 8VLBWS00
Mfr#: FWD-32B1
The 32" LCD display offers high quality images to bring excellent color reproduction and high visibility for indoor applications.
The FWD-32B1 display has been designed to be mounted horizontally and vertically for use in a variety of digital signage applications including retail.
Due to the commercial-grade LCD panel, these displays are suitable for continuous 24 hour (24/7) applications.
Sony FWD-32B1 32" LCD flat panel display
110 Watt
Diagonal Class
32"
Commercial Use
Yes - digital signage
76.33 cm x 11.69 cm x 45.79 cm - without stand
13.4 kg
Country Kits
Europe
Resolution
1366 x 768
Display Format
720p
Video Interface
Component, composite, HDMI
LAN
PC Interface
VGA (HD-15)
TV Tuner
No tuner
Screen saver, Eco Mode, portrait mode, Certified for 24/7 Continuous Operation, landscape mode, control panel lockout, Power on Delay
Sound Output Mode
Stereo
Speaker System
2 speakers
Remote Control
Remote control
AC 120/230 V ( 50/60 Hz )
3 years warranty
110 Watt
Diagonal Class
32"
Commercial Use
TV Tuner
No tuner
Video Interface
PC Interface
VGA (HD-15)
Dimensions
Without stand
76.33 cm
11.69 cm
45.79 cm
13.4 kg
Country Kits
Europe
Display
Resolution
1366 x 768
Display Format
720p
Colour Depth
16.7 million colours
Image Contrast Ratio
3000:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.51 x 0.51 mm
Stands & Mounts
Flat Panel Mount Interface
200 x 200 mm
Video Features
Analogue Video Input Signals
NTSC, PAL
Remote Control
Remote control
Remote Control Model
Sony RM-FW002
Audio System
Sound Output Mode
Stereo
Speaker System
2 speakers
Output Power / Total
14 Watt
Speakers
2 x main channel speaker - built-in - 7 Watt
Network & Internet Multimedia
LAN
LAN Protocol
Ethernet
Connector Type
1 x HDMI , 1 x audio line-in , 1 x VGA / component video input ( 15 PIN HD D-Sub (HD-15) ) , 1 x composite video input ( BNC ) , 1 x composite video output ( BNC ) , 1 x component video input ( RCA x 3 ) , 1 x network ( RJ-45 ) , 1 x serial ( 9 PIN D-Sub ) , 1 x audio line-out ( RCA x 2 )
2 AA batteries
FCC Class B certified, CSA, UL, IC, CISPR, GOST-R, Energy-Related Products (ErP) Lot 6
Power supply
Nominal Voltage
Limited warranty - 3 years
20 - 90% (non-condensing)
