BT.com
Wishlist
Sony DVP-SR170 Slim DVD Player - Black
Delivery
Standard Due date unavailable
This compact 270 mm wide DVD player fits neatly into the smallest space but gives you multi-format playback of your discs. Plus, it connects simply to your Hi-Fi system, to quickly upgrade the sound of your movie. Its compact size makes this the perfect DVD player for kitchen or bedroom. It can play multi-format movies, music and photos. Now you can enjoy fast playback with recognizable sound to add to your viewing enjoyment. You can also playback slowly with sound to monitor sports action or listen to a language study program.
Sony DVP-SR170 - DVD player
DVD player
27 cm x 20.7 cm x 3.85 cm
950 g
Media Type
CD-R, CD-RW, SVCD, DVD-R, DVD+RW, DVD-RW, DVD+R, DVD+R DL, DVD-R DL, CD-DA
Media Format
NTSC, PAL
Video D/A Converter
12bit / 108MHz
Remote Control
Remote control - infrared
Sound Output Mode
Stereo
AC 230V ( 50/60 Hz )
Tabletop
DVD player
Tabletop
27 cm
20.7 cm
3.85 cm
950 g
DVD
Media Type
Media Format
NTSC, PAL
Video D/A Converter
12bit / 108MHz
Media Load Type
Tray
Supported Digital Video Standards
MPEG-1, MPEG-4
Supported Digital Audio Standards
WMA, AAC, MP3, LPCM
Supported Digital Photo Standards
JPEG
DVD Features
Parental Lock
Sharpness control, JPEG photo playback
Audio System
Sound Output Mode
Stereo
Digital Audio Format
Dolby Digital output, DTS digital output
Screen saver, CD Text capable, DVD-Text capable, VCD playback
Remote Control
Remote control
Remote Control Technology
Infrared
Connector Type
SCART ( 21 PIN SCART ) - rear
Power supply
Power Consumption Stand by / Sleep
0.5 Watt
Scroll to top
