BT.com
Wishlist
Sony Bravia KDL32R403 32" LED Freeview TV
Delivery
Standard Due date unavailable
Crisp HD pictures are only the start. Enjoy slim styling that looks great wall mounted. Record TV shows onto a USB drive to enjoy any time.
Sony KDL-32R403C BRAVIA R403C Series - 32" LED TV
LED-backlit LCD TV
Diagonal Class
32"
Resolution
1366 x 768
Display Format
720p
Input Video Formats
1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 576/50p, 1080/50p, 1080/60p, 1080/30p, 480/60i, 576/50i, 720/24p, 720/30p
Motion Enhancement Technology
Motionflow XR 100 technology
24p Technology
24p True Cinema
Video Interface
Component, composite, HDMI, SCART
HDMI Ports Qty
2 ports
HDCP Compatible
LCD Backlight Technology
LED backlight - edge-lit
Image Aspect Ratio
16:9
TV Tuner
1x analogue, 1x digital
Digital TV Tuner
DVB-C, DVB-T, DVB-T2
Speaker System
2 speakers
Stereo Reception System
NICAM, A2
USB
Remote Control
Standard remote
Energy Class
Class A+
45 Watt
Power Consumption (On mode)
31 W
Energy Consumption per Year
45 kWh
73.8 cm x 6.5 cm x 44.1 cm
5.8 kg
LED-backlit LCD TV
Energy Class
Class A+
45 Watt
31 W
45 kWh
Diagonal Class
32"
Series
BRAVIA R403C Series
TV Tuner
Video Interface
HDMI Ports Qty
2 ports
HDCP Compatible
Modes
Film Mode, backlight off mode
Timer Functions
Sleep, wake
Dimensions
Without stand
73.8 cm
6.5 cm
44.1 cm
5.8 kg
Display
Resolution
1366 x 768
Display Format
720p
Image Aspect Ratio
16:9
24p Technology
24p True Cinema
Widescreen Modes
Zoom 14:9, Auto Wide, Full, Wide Zoom, Zoom, Normal, Caption
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Advanced Contrast Enhancer circuit (ACE), Clear Resolution Enhancer, CineMotion, Cinema Drive, Dynamic Backlight Control
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Stand Colour
Mold matte black
Flat Panel Mount Interface
TV Tuner
Conditional Access
Common Interface Plus (CI+) slot
NICAM, A2
Digital TV Tuner
Digital TV Tuner
Video Features
Input Video Formats
Electronic Programme Guide
Digital EPG
Parental Channel Lock
Media Player
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Remote Control Model
Sony RM-ED062
Scene Select
Audio System
Digital Audio Format
Dolby Digital output, Dolby Digital Plus output, Dolby Pulse output
Audio Controls
Sound mode
Speaker System
2 speakers
Output Power / Total
10 Watt
S-Master Digital Amplifier, Clear Phase Speaker
Speakers
2 x main channel speaker - built-in - 5 Watt
Network & Internet Multimedia
Supported Consumer Electronics Control (CEC)
BRAVIA Sync Function
Connector Type
HDMI input - side , HDMI input - rear , SCART - rear , USB - side , Composite video / component video input - bottom , Audio line-in , Digital audio output (optical) - bottom , Audio line-out / headphones / subwoofer - side , Network - bottom
Batteries
Power supply
Power Consumption Stand by
0.5 Watt
Dimensions & Weight Details
Panel without stand - 73.8 cm x 6.5 cm x 44.1 cm x 5.8 kg , Panel with stand - 73.8 cm x 15.1 cm x 47 cm x 6.3 kg
Width (Shipping)
83.6 cm
Depth (Shipping)
15.8 cm
Height (Shipping)
53.5 cm
Scroll to top
