BT.com
Wishlist
Sony Alpha SLT-A58K - Digital SLR - 20.1 Mpix - 3 x optical zoom DT 18-55mm lens
Delivery
Standard Due date unavailable
Capture decisive moments like a true professional. The Alpha a58 unites high-end camera technology with more features and user-friendly operation to enable comfortable, carefree shooting with impressive results. Every curve and detail of its sophisticated body has been painstakingly refined to enhance your handling ease. Whether shooting photos or Full HD video, it's now easier than ever to elevate your images with the refinement and creative freedom of interchangeable-lens photography.
The Alpha a58 features a 20.1-megapixel Exmor HD APS sensor for lavishly detailed photos that make for gorgeous enlargements - not to mention Full HD video of incredible richness and clarity. Thanks to the large APS-C size sensor and premium Sony Exmor APS HD CMOS technology, the camera achieves high resolution with no penalty in low-light sensitivity or sensor noise. And with continuous shooting of up to 5 fps, you'll never miss a moment.
Unlike other DSLRs, the a58 captures up to 5 fps at full 20.1-megapixel resolution with continuous autofocus thanks to the power of Sony's award-winning Translucent Mirror Technology. This groundbreaking technology directs light to both the image sensor and Phase Detection AF sensor simultaneously for enhanced autofocus performance plus blazing speed and precision.
When shooting quick-moving subjects - think kids playing soccer or a seagull in flight - it can sometimes be difficult to maintain a crisp focus. Using Sony's Translucent Mirror technology and advanced face/object detection, lock-on AF continuously adjusts the target frame size based on various subject characteristics and dramatically increases the in-focus rate. Even if your subject's face cannot be detected, the lock-on AF ensures smooth, stable focusing using the optimal AF point - without having to search.
What's in the box
  • Sony a SLT-A58K
  • DT 18-55mm lens
  • Sony NP-FM500H Battery
  • Battery charger, dust cap, WhatsInTheBox cap, lens cap, shoulder strap, USB cable
Sony a SLT-A58K - digital camera DT 18-55mm lens
Digital camera - SLR with Live View mode, movie recording
Lens Included
DT 18-55mm lens
Memory Card Slot
Memory Stick PRO Duo card, SD card
Image Processor
BIONZ
Sensor Resolution
20.1 Megapixel
Max Video Resolution
1920 x 1080
Lens System
Zoom lens - 3x zoom - 18 - 55 mm - f/3.5-5.6 DT SAM II
Focus Adjustment
Automatic, manual
Min Focus Distance
25 cm
Image Stabiliser
Optical (SteadyShot INSIDE)
Camera Flash
Pop-up flash
Viewfinder
Electronic - colour - OLED
Display
LCD display - 2.7"
Supported Battery
1 x Sony NP-FM500H Li-ion rechargeable battery (included)
HDMI, USB 2.0
12.86 cm x 7.77 cm x 9.55 cm
492 g
Lens Included
DT 18-55mm lens
Sensor Resolution
20.1 Megapixel
Optical Sensor Type
Exmor APS HD CMOS
Total Pixels
20,400,000 pixels
Effective Sensor Resolution
20,100,000 pixels
Optical Sensor Size
APS-C (23.2 x 15.4 mm)
Field of View Crop Factor
1.5
ISO (Max)
16000
Sensor Features
Anti-Dust coating
Optical Zoom
3x
Image Processor
BIONZ
Image Stabiliser
Built-in Optical Image Stabiliser
Face Detection
Surround Sound
Dolby Digital AC-3 (2 channel) recording
Print Standard
DPOF support, Exif Print support, PRINT Image Matching
Auto Focus
TTL phase detection
Auto Focus Points (Zones) Qty
15
AE/AF Control
Eye Control, Predictive AI Servo AF
Face Detection
Face Detection AF/AE/FE/WB, Face Recognition
Digital Video Format
AVCHD, H.264
Image Recording Format
JPEG, RAW, RAW + JPEG
1920 x 1080
HDMI, USB 2.0
Exposure & White Balance
Light Sensitivity
ISO auto, ISO 100-16000
Exposure Metering
Multi-segment, centre-weighted, spot
Exposure Metering Zones
1200
Exposure Modes
Programme, bulb, automatic, manual, aperture-priority, shutter-priority
Special Effects
Black & White, Vivid, sunset, landscape, portrait
White Balance
Custom, automatic, presets
White Balance Presets
Incandescent, fluorescent, cloudy, Flash, daylight, shade, 2500K - 9900K
Max Shutter Speed
1/4000 sec
Min Shutter Speed
30 sec
Exposure Compensation
±3 EV range, in 1/3 EV steps
Auto Exposure Bracketing
3 steps
X-sync Speed
1/160 sec
Lens System
Zoom lens - 3x zoom - 18 - 55 mm - f/3.5-5.6 DT SAM II - zoom
Focal Length Equivalent to 35mm Camera
27 - 82.5mm
Focus Adjustment
Automatic, manual
Min Focus Distance
25 cm
Max View Angle
76 degree(s)
Zoom Adjustment
Manual
Lens Construction
7 groups / 8 elements
Filter Size
55 mm
Aspherical lens, Smooth Autofocus Motor (SAM)
Camera Flash
Camera Flash
Pop-up flash
Guide Number (m / ISO 100)
10
Flash Modes
Fill-in mode, rear curtain sync, slow synchro, auto mode, flash OFF mode, red-eye reduction
Red-Eye Reduction
AF illuminator, flash +/- compensation, wireless off-camera control, flash exposure bracketing
Additional Features
Continuous Shooting Speed
8 frames per second
Self-Timer Delay
10 sec, 2sec
Flash Terminal
Hot shoe
Additional Features
RGB primary colour filter, digital noise reduction, depth-of-field preview button, sharpness control, digital image rotation, camera orientation detection, histogram display, saturation control, Sweep Panorama technology, LCD live view mode, Dynamic Range Optimizer, built-in help guide, automatic display brightness adjustment, Multi-Frame Noise Reduction, Intelligent AUTO (iAUTO), AUTO+ (Advanced AUTO) mode, noise reduction over long exposures, high ISO speed noise reduction, Auto Object Framing, Translucent Mirror technology
Viewfinder
Viewfinder Type
Electronic - OLED
Viewfinder Colour Support
Optical Viewfinder Field Coverage
100%
Optical Viewfinder Magnification
0.88x
Optical Viewfinder Dioptric Correction Range
-4 to +4
Auto eye sensor
Display
2.7" LCD display
Display Format
460,000 pixels
Display Form Factor
Folding
Display Features
Contrast control, display brightness control
Connector Type
HDMI output , USB 2.0
Battery charger, dust cap, body cap, lens cap, shoulder strap, USB cable
Battery Type
Sony NP-FM500H Lithium Ion - manufacturer-specific
Details
Battery Life Details
Photo shooting - 690 shots (EVF on) , Photo shooting - 700 shots (LCD Monitor on)
Memory / Storage
Memory Card Slot
Supported Memory Cards
SD Memory Card, Memory Stick PRO Duo, SDXC Memory Card, SDHC Memory Card, Memory Stick PRO-HG Duo
Image Storage
5456 x 3632 , 3872 x 2576 , 2736 x 1824
Video Capture
AVCHD - 1920 x 1080 - 50 fps - 24Mbps , AVCHD - 1920 x 1080 - 50 fps - 17Mbps , AVCHD - 1920 x 1080 - 25 fps - 24Mbps , AVCHD - 1920 x 1080 - 25 fps - 17Mbps , H.264 - 1440 x 1080 - 25 fps - 12Mbps
12.86 cm
7.77 cm
9.55 cm
492 g
Scroll to top
