BT.com
Wishlist
Sony a NEX 3NY - 16.1 Mpix - 3x optical zoom 16-50mm and 55-210mm lenses - black
Delivery
Standard Due date unavailable
Take the creativity of a DSLR anywhere with the easy-to-use NEX-3N. With a large 16.1-megapixel APS-C sensor, you can shoot detailed images in low light, use the handy 180° tiltable screen for self-portraits or tricky angles, and give your photography that professional look.
The NEX-3N body is slim and light, and ready to go where you go, but it also has the capabilities of DSLR cameras twice its size. What's more, you're ready for any scene with a lightweight power zoom lens and compact telephoto lens to pull your subject closer.
Sony a NEX 3NY - digital camera 16-50mm and 55-210mm lenses
Digital camera - mirrorless system
Lens Included
Memory Card Slot
Memory Stick PRO Duo card, SD card
Image Processor
BIONZ
Sensor Resolution
16.1 Megapixel
Max Video Resolution
1920 x 1080
Lens System
Zoom lens - 3 x zoom - 16 - 50 mm - f/3.5-5.6 PZ OSS
Lens System (2nd)
Telephoto lens - 3.8 x zoom - 55 - 210 mm - f/4.5-6.3
Focus Adjustment
Automatic, manual
Min Focus Distance
25 cm
Digital Zoom
4 x
Image Stabiliser
Optical (Steady Shot)
Camera Flash
Pop-up flash
Display
LCD display - 3"
Supported Battery
1 x Sony NP-FW50 Li-ion rechargeable battery ( included )
Interfaces Provided
HDMI
Microsoft Certification
Compatible with Windows 7
10.99 cm x 3.46 cm x 6.2 cm
210 g
Lens Included
Enclosure Colour
Sensor Resolution
16.1 Megapixel
Optical Sensor Type
Exmor APS HD CMOS
Total Pixels
16,500,000 pixels
Effective Sensor Resolution
16,100,000 pixels
Optical Sensor Size
15.6 x 23.5mm
Field of View Crop Factor
1.5
ISO (Max)
16000
Optical Zoom
3 x
Digital Zoom
4 x
Image Processor
BIONZ
Image Stabiliser
Face Detection
Print Standard
DPOF support, Exif Print support, PRINT Image Matching
Auto Focus
TTL contrast and phase detection
Auto Focus Points (Zones) Qty
25
AE/AF Control
Subject-tracking AF
Face Detection
Smile Shutter
Digital Video Format
AVCHD, H.264
Image Recording Format
JPEG, RAW, RAW + JPEG
1920 x 1080
Interfaces Provided
HDMI
Exposure & White Balance
Light Sensitivity
ISO auto, ISO 200-16000
Exposure Metering
Multi-segment, centre-weighted, spot
Exposure Metering Zones
1200
Exposure Modes
Programme, bulb, automatic, manual, aperture-priority, shutter-priority
Special Effects
Black & White, Vivid, sunset, soft focus, landscape, portrait, miniature, Retro, partial colour, Toy camera, Posterisation, High contrast monochrome, Pop Colour, HDR Painting, Rich-tone monochrome, Soft High-key
White Balance
Custom, automatic, presets
White Balance Presets
Incandescent, fluorescent, cloudy, Flash, daylight, shade, 2500K - 9900K
Max Shutter Speed
1/4000 sec
Min Shutter Speed
30 sec
Exposure Compensation
±3 EV range, in 1/3 EV steps
Auto Exposure Bracketing
3 steps
X-sync Speed
1/160 sec
Lens System
Focal Length Equivalent to 35mm Camera
24 - 75mm
Focus Adjustment
Automatic, manual
Min Focus Distance
25 cm
Max View Angle
83 degree(s)
Zoom Adjustment
Manual (by ring), motorised drive
Lens Construction
8 groups / 9 elements
Filter Size
40.5 mm
Lens Mounting Type
Sony E-mount
ED glass, aspherical lens, Lens Barrel Retraction Function
Lens System (2nd)
82.5 - 315mm
Min Focus Distance
1 m
Focus Adjustment
Automatic, manual
Lens Construction
9 groups / 13 elements
Filter Size
49 mm
ED glass
Camera Flash
Camera Flash
Pop-up flash
Guide Number (m / ISO 100)
6
Flash Modes
Fill-in mode, rear curtain sync, slow synchro, auto mode, flash OFF mode
AF illuminator, flash +/- compensation
Additional Features
Continuous Shooting Speed
2.5 frames per second
Self Timer Delay
10 sec, 2sec
Additional Features
Built-in speaker, RGB primary colour filter, sharpness control, digital image rotation, camera orientation detection, histogram display, AE lock, AF lock, saturation control, Sweep Panorama technology, Dynamic Range Optimizer, face detection, USB charging, 25p Cinema Mode, Intelligent AUTO (iAUTO), Superior Auto mode, long exposure noise reduction, high ISO speed noise reduction, BRAVIA Sync function, Auto Object Framing
Display
3" LCD display
Resolution
460,800 pixels
Display Form Factor
Folding
Display Features
Contrast control, display brightness control
Microphone
Microphone Operation Mode
Stereo
Connector Type
1 x USB 2.0 , 1 x HDMI output
Software
Software
Drivers & Utilities
Battery Type
Sony NP-FW50
Details
Battery Life Details
Photo shooting - 480 shots
Memory / Storage
Memory Card Slot
Supported Memory Cards
SD Memory Card, Memory Stick PRO Duo, SDXC Memory Card, Memory Stick PRO-HG Duo HX, SDHC Memory Card, Memory Stick PRO-HG Duo
Image Storage
JPEG 4912 x 2760 , JPEG 3568 x 2000 , JPEG 2448 x 1376
Video Capture
AVCHD - 1920 x 1080 - 50 fps - 24Mbps , AVCHD - 1920 x 1080 - 50 fps - 17Mbps , AVCHD - 1920 x 1080 - 25 fps - 24Mbps , AVCHD - 1920 x 1080 - 25 fps - 17Mbps , H.264 - 1440 x 1080 - 25 fps - 12Mbps , H.264 - 640 x 480 - 25 fps - 3Mbps
10.99 cm
3.46 cm
6.2 cm
210 g
Scroll to top
