BT.com
Wishlist
Sony a Alpha SLT-A58Y - Digital SLR - 20.1 Mpix - 18-55mm and 55-200mm lenses - black
Delivery
Standard Due date unavailable
Create images with impact with the 20.1-meganixel Exmor APS HD CMOS sensor. With its wide sensitivity range, it picks up on every little detail - even in low-light conditions. Together with the BIONZ image processing engine, it ensures crisp, clear pictures every time.
With some viewfinders, shots don't turn out quite as expected. But the high-contrast OLED Tru-Finder gives an accurate, real-time display of the shot you're about to take - right down to camera settings and exposure adjustments. So you can compose with confidence.
Sony a SLT-A58Y - digital camera DT 18-55mm and 55-200mm lenses
Digital camera - SLR with Live View mode, movie recording
Lens Included
Memory Card Slot
Memory Stick PRO Duo card, SD card
Image Processor
BIONZ
Sensor Resolution
20.1 Megapixel
Max Video Resolution
1920 x 1080
Lens System
Zoom lens - 3x zoom - 18 - 55 mm - f/3.5-5.6 DT SAM II
Lens System (2nd)
Zoom lens - 3.6x zoom - 55 - 200 mm - f/4.0-5.6 DT SAM
Focus Adjustment
Automatic, manual
Min Focus Distance
25 cm
Image Stabiliser
Optical (SteadyShot INSIDE)
Camera Flash
Pop-up flash
Viewfinder
Electronic - 0.5" - colour - OLED
Display
LCD display - 2.7"
Supported Battery
1 x Sony NP-FM500H Li-ion rechargeable battery - 1600 mAh (included)
HDMI, USB 2.0
12.9 cm x 7.8 cm x 9.6 cm
492 g
Lens Included
Enclosure Colour
Sensor Resolution
20.1 Megapixel
Optical Sensor Type
Exmor APS HD CMOS
Total Pixels
20,400,000 pixels
Effective Sensor Resolution
20,100,000 pixels
Optical Sensor Size
15.4 x 23.2mm
Field of View Crop Factor
1.5
ISO (Max)
16000
Sensor Dust Reduction
Sensor Features
Anti-Dust coating
Optical Zoom
3x
Image Processor
BIONZ
Image Stabiliser
Face Detection
Surround Sound
Dolby Digital AC-3 (2 channel) recording
Print Standard
DPOF support, Exif Print support, PRINT Image Matching
Auto Focus
TTL phase detection
Auto Focus Points (Zones) Qty
15
AE/AF Control
Face-priority AF, Subject-tracking AF
Face Detection
Face Detection AF/AE/FE/WB, Face Recognition, Smile Shutter
Digital Video Format
AVCHD, H.264
Image Recording Format
JPEG, RAW, RAW + JPEG
1920 x 1080
Auto Focus Features
Manual Focus Check Live View
HDMI, USB 2.0
Exposure & White Balance
Light Sensitivity
ISO auto, ISO 100-16000
Exposure Metering
Multi-segment, centre-weighted, spot
Exposure Metering Zones
1200
Exposure Modes
Programme, bulb, automatic, manual, aperture-priority, shutter-priority
Shooting Programs
Landscape, portrait mode, macro, night portrait, sports mode, sunset, handheld twilight, Night View
Special Effects
Black & White, Vivid, sunset, soft focus, landscape, portrait, miniature, Retro, partial colour, Toy camera, Posterisation, High contrast monochrome, Pop Colour, HDR Painting, Rich-tone monochrome, Soft High-key
White Balance
Custom, automatic, presets
White Balance Presets
Incandescent, fluorescent, cloudy, Flash, daylight, shade, 2500K - 9900K
Max Shutter Speed
1/4000 sec
Min Shutter Speed
30 sec
Exposure Compensation
±3 EV range, in 1/3 EV steps
Auto Exposure Bracketing
5 steps in 1/3, 1/2, 2/3, 2 or 3 EV steps
White Balance Bracketing
X-sync Speed
1/160 sec
Lens System
Zoom lens - 3x zoom - 18 - 55 mm - f/3.5-5.6 DT SAM II - zoom
Focal Length Equivalent to 35mm Camera
27 - 82.5mm
Focus Adjustment
Automatic, manual
Min Focus Distance
25 cm
Max View Angle
76 degree(s)
Zoom Adjustment
Manual
Lens Construction
7 groups / 8 elements
Filter Size
55 mm
Aspherical lens, Smooth Autofocus Motor (SAM)
Lens System (2nd)
82.5 - 300mm
Min Focus Distance
95 cm
Focus Adjustment
Automatic, manual
Lens Construction
9 groups / 13 elements
Filter Size
55 mm
ED glass
Camera Flash
Camera Flash
Pop-up flash
Guide Number (m / ISO 100)
10
Flash Modes
Fill-in mode, rear curtain sync, slow synchro, auto mode, flash OFF mode, red-eye reduction
AF illuminator, flash +/- compensation, wireless off-camera control, flash exposure bracketing
Additional Features
Continuous Shooting Speed
8 frames per second
Self-Timer Delay
10 sec, 2sec
Flash Terminal
Hot shoe
Additional Features
RGB primary colour filter, depth-of-field preview button, sharpness control, digital image rotation, camera orientation detection, histogram display, saturation control, Sweep Panorama technology, shadow point display, highlight point display, Dynamic Range Optimizer, built-in help guide, automatic display brightness adjustment, Multi-Frame Noise Reduction, Intelligent AUTO (iAUTO), AUTO+ (Advanced AUTO) mode, Superior Auto mode, noise reduction over long exposures, high ISO speed noise reduction, BRAVIA Sync function, Auto Object Framing, Translucent Mirror technology
Viewfinder
Viewfinder Type
Electronic - OLED
Viewfinder Colour Support
Viewfinder Diagonal Size
0.5"
Viewfinder Resolution
1,440,000 pixels
Optical Viewfinder Field Coverage
100%
Optical Viewfinder Magnification
0.88x
Optical Viewfinder Dioptric Correction Range
-4 to +4
Auto eye sensor
Display
2.7" LCD display
Resolution
460,800 pixels
Display Form Factor
Folding
Display Features
Contrast control, display brightness control
Microphone
Microphone Operation Mode
Stereo
Connector Type
HDMI output , USB 2.0
Software
Software
Sony PlayMemories Home, Sony Image Data Converter 4.0
Battery charger, dust cap, body cap, lens cap, shoulder strap, USB cable
Battery Type
Sony NP-FM500H
Details
Battery Life Details
Photo shooting - 690 shots (EVF on) , Photo shooting - 700 shots (LCD Monitor on)
Memory / Storage
Memory Card Slot
Supported Memory Cards
SD Memory Card, Memory Stick PRO Duo, SDXC Memory Card, Memory Stick PRO-HG Duo HX, SDHC Memory Card, Memory Stick PRO-HG Duo
Image Storage
5456 x 3632 , 3872 x 2576 , 2736 x 1824
Video Capture
AVCHD - 1920 x 1080 - 50 fps - 24Mbps , AVCHD - 1920 x 1080 - 50 fps - 17Mbps , AVCHD - 1920 x 1080 - 25 fps - 24Mbps , AVCHD - 1920 x 1080 - 25 fps - 17Mbps , H.264 - 1440 x 1080 - 25 fps - 12Mbps
12.9 cm
7.8 cm
9.6 cm
492 g
Scroll to top
