BT.com
Wishlist
Sony 8.9 Megapixels 27x Opt Zoom 320x Dig Zoom 2.7" LCD Screen
Delivery
Standard Due date unavailable
See things differently with a camcorder with built-in projector. Shoot in Full HD then watch your movies anytime, anywhere, on a big or small screen. Cram more detail into every frame you film, even in low light, and get more of the shots you want to share on the big screen.
With a built-in projector, the world is your movie theater. On the beach, at a party or a wedding reception, shoot and share footage straightaway on any available surface. See a bright, clear picture with vivid colors, even in daylight, up to 250 cm (100-inch) big.
Just because daylight's fading or the room is dimly lit, don't let that stop you. The Exmor R CMOS is twice as sensitive as conventional sensors, capturing every detail, even without flash. No more grainy, fuzzy, dim images - just crisp, clear pictures.
From a bustling market to a crowded dancefloor, be sure to fit everything and everyone you want into your shots. With a wide-angle Vario-Tessar lens by Carl Zeiss, you can capture a larger image area without having to stand back - and without compromising detail.
When you're filming up close, or shooting action scenes, record high quality images in smooth, sharp detail. It's all thanks to the 50p progressive shooting mode and its speedy rate of image capture which means you can re-live every smile, goal or sunset as you remember it.
Sony Handycam HDR-PJ220E - camcorder - Carl Zeiss - storage: flash card
Camcorder - 1080p - widescreen with projector
Lens Included
Carl Zeiss
Built-in Projector
nHD - 640 x 360 - 13 lumens
Media Type
Flash card
Memory Card Slot
Memory Stick PRO Duo card, SD card
Image Processor
BIONZ
Sensor Resolution
2.39 MP
Effective Sensor Resolution
Video: 2.15 MP - Photo: 2.29 MP
Lens System
Zoom lens - 27x zoom - 2.1 - 57 mm - f/1.9-4.0
Focus Adjustment
Automatic, manual
Digital Zoom
320x
Image Stabiliser
Electronic (Steady Shot with Active Mode)
Display
LCD display - 2.7"
Supported Battery
1 x Sony NP-FV30 Li-ion rechargeable battery (included)
Composite video/audio, HDMI, USB 2.0
Microsoft Certification
Compatible with Windows 7
5.8 cm x 11.7 cm x 5.7 cm
210 g
Camcorder - 1080p with projector
Lens Included
Carl Zeiss
Enclosure Colour
Camcorder Sensor Resolution
2.39 MP
Effective Video Resolution
2.15 MP
Effective Photo Resolution
2.29 MP
Camcorder Interpolated Photo Resolution
8.9 MP
Widescreen Video Capture
Camcorder Media Type
Flash card
Optical Sensor Type
Exmor R CMOS
Optical Sensor Size
1/5.8"
Optical Zoom
27x
Digital Zoom
320x
Video Recording Modes
LP, FH, HQ, FX, PS
Image Processor
BIONZ
Image Stabiliser
Face Detection
Surround Sound
Dolby Digital AC-3 (2 channel) recording
Print Standard
Exif Print support
Auto Focus
TTL contrast detection
AE/AF Control
Face-priority AF
Face Detection
Face-priority AF function, Smile Shutter, Child Priority, Adult Priority
Digital Video Format
MPEG-2, AVCHD
Image Recording Format
JPEG
Audio Signal Format
Dolby Digital AC-3 (2 channel), AAC
Exposure & White Balance
Min Illumination
3 lux
Exposure Modes
Programme, automatic
Shooting Programs
Spotlight, landscape, portrait mode, fireworks, sunset, beach, snow, sunrise
White Balance
Custom, automatic, presets
White Balance Presets
Indoor, outdoor
Max Shutter Speed
1/10000 sec
Min Shutter Speed
1/25 sec
Lens System
Carl Zeiss zoom lens - 27x zoom - 2.1 - 57 mm - f/1.9-4.0
Focal Length Equivalent to 35mm Camera
29.8 - 953.6mm
Focus Adjustment
Automatic, manual
Zoom Adjustment
Motorised drive
Built-in lens shield
Additional Features
Self-Timer Delay
10 sec
Low Lux / Night Mode
Additional Features
Built-in speaker, auto power save, digital noise reduction, date/time stamp, takes photos while film recording, USB charging, auto backlight compensation, Dolby Digital Stereo Creator, x.v.Colour technology, Intelligent AUTO (iAUTO), built-in USB plug, BRAVIA Sync function
Display
2.7" LCD display
Resolution
230,000 pixels
Display Form Factor
Rotating (270°)
Display Features
Display brightness control
Built-in Projector
Max Image Brightness
13 lumens
Max Image Size
254 cm
Resolution
nHD - 640 x 360
Microphone
Microphone Operation Mode
Stereo
Microphone Features
Zoom, wind noise reduction, sensitivity control
Connector Type
USB 2.0 , Composite video/audio output , HDMI output , DC power input
Software
Software
Sony PlayMemories Home Lite
Power adapter, HDMI cable, USB extension cable
Battery Type
Sony NP-FV30
Details
Battery Life Details
Projection - 0.8 hours
Memory / Storage
Memory Card Slot
Supported Memory Cards
SD Memory Card, Memory Stick PRO Duo, SDXC Memory Card, Memory Stick PRO Duo Mark2, SDHC Memory Card, Memory Stick PRO-HG Duo
Image Storage
JPEG 3984 x 2240 , JPEG 2992 x 2240 , JPEG 2816 x 1584 , JPEG 1920 x 1080
Video Capture
AVCHD - 1920 x 1080 - 50 fps - 28Mbps , AVCHD - 1920 x 1080 - 50 fps - 24Mbps , AVCHD - 1920 x 1080 - 50 fps - 17Mbps , AVCHD - 1440 x 1080 - 50 fps - 9Mbps , AVCHD - 1440 x 1080 - 50 fps - 5Mbps , MPEG-2 - 720 x 576 - 50 fps - 9Mbps
5.8 cm
11.7 cm
5.7 cm
210 g
Scroll to top
