BT.com
Wishlist
Sony 3000 ANSI Lumens XGA Projector - 2.2kg
Delivery
Standard Due date unavailable
The VPL-DX15 projector has been designed to be a compact and portable projector which is simple to use but also incorporates a range of innovative features including built-in wireless connectivity, a USB file viewer and the capacity to stream video. This projector incorporates Sony's BrightEra panel technology, delivering a color light output of 3000 ANSI lumens and excellent picture quality at XGA resolution. This allows professional presentations to be delivered in virtually any setting.
This projector has a footprint smaller than an A4 sheet of paper. This means it can easily be carried between meeting rooms and is ideal for use in small to medium sized presentation rooms, including corporate conference rooms and school classrooms.
Sony VPL-DX15 LCD projector
LCD projector
Built-in Devices
Speaker
Brightness
3000 lumens
Brightness (Colour)
3000 lumens
Contrast Ratio
700:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Bulb type
UHP 200 Watt
Bulb life cycle
Up to 2000 hour(s) / up to 3000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video, component video (SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58), IEEE 802.11g wireless / LAN
Video Modes
575/50i, 575/50p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 480/60i
Speakers
Speaker(s) - integrated
320 Watt
29.5 cm x 20.4 cm x 7.4 cm
2.2 kg
LCD projector
Built-in Devices
Speaker
Projector
Brightness
3000 lumens
Brightness (Colour)
3000 lumens
Brightness (Reduced)
2400 lumens
Contrast Ratio
700:1
Image Size
102 cm - 762 cm
Throw Ratio
1.5 - 1.8:1
Digital Zoom Factor
4x
Resolution
XGA - XGA (1024 x 768) (native) / 1400 x 1050 (resized)
Native Aspect Ratio
4:3
Display Format
2,359,296 pixels (1024 x 768)
Max Sync Rate (V x H)
92 Hz x 80 kHz
Bulb type
UHP 200 Watt
Bulb life cycle
Freeze frame, Picture Muting, BrightEra
Lens
Lens Aperture
F/1.65-1.8
Zoom Type
Powered
Zoom Factor
1.2x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-30 / +30
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, composite video, S-Video
Video Modes
LAN and Wireless Image Transferring Protocols
IEEE 802.11b, IEEE 802.11g, wired LAN, IEEE 802.11a
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
1 Watt
Speakers
1 x mixed channel
Input Device
External
1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x network - RJ-45 , 1 x USB - 4 pin USB Type A
Carrying case, wireless remote control
1 x VGA cable - 2 m
Security Features
Security lock slot (cable lock sold separately), password protection, control panel lock
FCC Class B certified, IC Class B, CSA, VCCI, C-Tick, cUL, DEMKO, EN55022 Class B, CB, EMC, EK, UL 60950-1, IEC 60950-1, EN 60950-1, JEITA
Nominal Voltage
320 Watt
Power Consumption Operational (Standby)
3 Watt
29.5 cm
20.4 cm
7.4 cm
2.2 kg
35 °C
10 - 90%
Scroll to top
