BT.com
Wishlist
SonicWALL SonicPoint ACi Radio Access Point with SonicWALL 802.3at Gigabit PoE Injector
SonicWALL SonicPoint ACi Radio...
£400.78
£400.78
Add to wishlist
Delivery
Standard 1-3 working days
Extend your network with secure, high-speed wireless. The Dell SonicPoint ACi wireless access point combines 802.11ac wireless performance, proven security, internal antennas and dimmable LEDs for discreet wireless networking environments.
SonicWall SonicPoint ACi - radio access point - with SonicWALL 802.3at Gigabit PoE Injector
Radio access point
Bundled Services
1 year Dynamic Support 24X7
External
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Virtual access points: 8 , Maximum number of clients: 256
Power Over Ethernet (PoE) Supported
PoE+
17.5 cm x 17.5 cm x 4 cm
480 g
Bundled with
Radio access point
Bundled Services
17.5 cm
17.5 cm
4 cm
480 g
Bundled with
External
Wireless
Data Transfer Rate
1.3 Gbps
Spread Spectrum Method
OFDM, DSSS
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Power, test mode, WLAN, LAN
Auto-sensing per device, VPN support, DFS support, firmware upgradable, wall mountable, Wireless Intrusion Detection System (WIDS), Access Control List (ACL) support, Wireless Guest Services, Samba support, Multiple SSID support, 3T3R MIMO technology, plenum-rated, ceiling mountable, Wireless Intrusion Prevention System (WIPS), Captive Portal, Virtual Access Points (VAP), Reassembly-Free Deep Packet Inspection (RFDPI)
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, 152-bit WEP, SSL, TKIP, WPA, WPA2, WPA-Enterprise, WPA2-Enterprise
Authentication Method
RADIUS, Active Directory, eDirectory, Transparent Active Directory Authentication (Single Sign-on)
IEEE 802.3i, IEEE 802.11b, IEEE 802.11a, IEEE 802.11d, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11n, IEEE 802.3at, IEEE 802.3e, IEEE 802.11ac
Aerial
Antenna
Internal
Antenna Qty
6
1 x 1000Base-T (PoE+) - RJ-45 , 1 x 1000Base-T - RJ-45 , 1 x console - RJ-45 , 1 x USB 2.0 - Type A
UL, TUV GS, BSMI, cUL, CB, UL 2043, FCC, RoHS, ICES Class B, WEEE, ANATEL, TELEC, VCCI Class B, NCC, RCM, MSIP, CoC
PoE+
Power injector
15.6 Watt
Extended service agreement - replacement - 1 year - shipment - response time: next day , Technical support - phone consulting - 1 year , Technical support - web support - 1 year , New releases update - 1 year
10 - 95% (non-condensing)
Scroll to top
