BT.com
Wishlist
SonicWALL SonicPoint ACe Radio Access Point with SonicWALL 802.3at Gigabit PoE Injector
SonicWALL SonicPoint ACe Radio...
£477.69
Hurry, only 1 left in stock!
£477.69
Add to wishlist
Delivery
Standard 1-3 working days
Take advantage of superior wireless network performance without sacrificing security. Dell SonicPoint ACe wireless access points use 802.11ac technology to provide high-speed wireless connectivity. Easily set up and manage all your SonicPoints from a single location.
SonicWall SonicPoint ACe - radio access point - with 1 year Dynamic Support 24X7 - with SonicWALL 802.3at Gigabit PoE Injector
Radio access point
Bundled Services
External
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Virtual access points: 8 , Maximum number of clients: 256
Power Over Ethernet (PoE) Supported
PoE+
17.5 cm x 17.5 cm x 3.8 cm
530 g
Bundled with
Radio access point
Bundled Services
17.5 cm
17.5 cm
3.8 cm
530 g
Bundled with
External
Wireless
Data Transfer Rate
1.3 Gbps
Spread Spectrum Method
OFDM, DSSS
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Power, test mode, WLAN, LAN
Auto-sensing per device, VPN support, DFS support, firmware upgradable, wall mountable, Wireless Intrusion Detection System (WIDS), Access Control List (ACL) support, Wireless Guest Services, Samba support, Multiple SSID support, 3T3R MIMO technology, plenum-rated, ceiling mountable, Wireless Intrusion Prevention System (WIPS), Captive Portal, Virtual Access Points (VAP), Reassembly-Free Deep Packet Inspection (RFDPI)
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, 152-bit WEP, SSL, TKIP, WPA, WPA2, WPA-Enterprise, WPA2-Enterprise
Authentication Method
RADIUS, Active Directory, eDirectory, Transparent Active Directory Authentication (Single Sign-on)
IEEE 802.3i, IEEE 802.11b, IEEE 802.11a, IEEE 802.11d, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11n, IEEE 802.3at, IEEE 802.3e, IEEE 802.11ac
Aerial
Antenna
External detachable
Antenna Qty
6
1 x 1000Base-T (PoE+) - RJ-45 , 1 x 1000Base-T - RJ-45 , 1 x console - RJ-45 , 1 x USB 2.0 - Type A
UL, TUV GS, BSMI, cUL, CB, UL 2043, FCC, RoHS, ICES Class B, WEEE, ANATEL, TELEC, VCCI Class B, NCC, RCM, MSIP, CoC
PoE+
External power adapter
15.2 Watt
Extended service agreement - replacement - 1 year - shipment - response time: next day , Technical support - phone consulting - 1 year , Technical support - web support - 1 year , New releases update - 1 year
10 - 95% (non-condensing)
Other bundles
SonicWALL SonicPoint ACe Radio Access Point with...
£477.69
C2G 2m Cat5e Cable with Homeplug
Save £2.00
£481.17
Scroll to top
