BT.com
Wishlist
SonicWALL SoHo Total Secure 1 Yr Firewall
SonicWALL SoHo Total Secure 1 Yr...
£439.53
25 in stock
£439.53
Add to wishlist
Delivery
Standard 1-3 working days
The Dell SonicWALL TZ series of nextgeneration firewalls (NGFW) is ideally suited for any organization that requires enterprise-grade network protection.
SonicWALL TZ series firewalls provide broad protection from compromise by combining advanced security services consisting of on-box and cloudbased anti-malware, anti-spyware, intrusion prevention system (IPS), and content/URL filtering. To counter the trend of encrypted attacks, the SonicWALL TZ series has the ability and processing power to inspect SSL connections against the latest threats, providing an even higher level of security. Backed by the Dell SonicWALL Global Response Intelligent Defense (GRID) network, the SonicWALL TZ series delivers continuous updates to maintain a strong network defense from cybercriminals. With full deep packet inspection operating at performance levels that match broadband connection speeds, the SonicWALL TZ Series is able to scan every byte of every packet on all ports and protocols with almost zero latency. This eliminates bottlenecks and allows organizations to use security as an enabler, not an inhibitor.
The SonicWALL TZ series also features an integrated wireless access controller, 1-Gigabit Ethernet ports, and native VPN remote access clients for Apple IOS, Google Android, Windows, Mac OS and Linux for fast, secure mobile access. The Dell SonicWALL Global Management System (GMS) enables deployment and management of SonicWALL TZ Series firewalls from a single system at the central office.
The products include fully tested routing features for IPv4 and IPv6, including route-based VPN protocols OSPF and RIP v1/v2. Authentication protocols support includes LDAP and RADIUS as well as single sign-on capability that can integrate with Active Directory. All Dell SonicWALL firewalls provide advanced threat protection from botnets, and UDP and ICMP flooding.
SonicWall SOHO - security appliance - with 1 year TotalSecure
Security appliance
Bundled Services
1 year TotalSecure
External
400 MHz
RAM
512 MB
Ports Qty
5
Performance
Firewall throughput: 300 Mbps , Full Deep Packet Inspection (DPI) throughput: 50 Mbps , IPS throughput: 100 Mbps , Anti-malware throughput: 50 Mbps , Firewall throughput (IMIX): 60 Mbps , SSL inspection throughput: 15 Mbps , VPN throughput: 100 Mbps , Connection rate: 1800 connections per second
Virtual interfaces (VLANs): 25 , SSL VPN licences: 1 (maximum 10) , VPN tunnels (site-to-site): 10 , IPSec VPN clients: 1 (maximum 5) , SPI connections: 25000 , DPI connections: 25000 , Authenticated users (internal database): 150 , Single Sign-On (SSO) users: 250 , Manageable access points: 16
VoIP Protocols
SIP, H.323 v3, H.323 v4, H.323 v1, H.323 v2, H.323 v5
19 cm x 14.1 cm x 3.6 cm
340 g
Security appliance
Bundled Services
1 year TotalSecure
19 cm
14.1 cm
3.6 cm
340 g
Processor / Memory / Storage
Processors Installed
400 MHz
RAM
512 MB
External
Ports Qty
5
Wired
Network / Transport Protocol
TCP/IP, PPTP, UDP/IP, L2TP, ICMP/IP, IPSec, PPPoE, DHCP
Routing Protocol
OSPF, RIP-1, RIP-2, BGP, static IP routing, policy-based routing (PBR)
Remote Management Protocol
SNMP 2, SNMP 3, HTTP, HTTPS, CLI
Performance
Firewall protection, VPN support, PAT support, VLAN support, Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, port mirroring, IPv6 support, antivirus analysis, Intrusion Prevention System (IPS), URL filtering, deep inspection, DDos attack prevention, Wi-Fi Multimedia (WMM) support, anti-spam protection, anti-malware protection, Quality of Service (QoS), Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T), DHCP server, bandwidth control, Common Access Card (CAC) reader support, anti-spyware protection, DHCP relay, 3G/4G USB Dongle Support, NetFlow, DiffServ Code Point (DSCP) support, Single Sign-On (SSO) support, anti-virus protection, keyword filtering
Encryption Algorithm
DES, Triple DES, MD5, SHA-1, 128-bit AES, 192-bit AES, 256-bit AES
Authentication Method
RADIUS, LDAP, internal user database, Active Directory, XAUTH authentication
IP Telephony
VoIP Protocols
Communications
Supported Flash Memory Cards
SDHC Memory Card
4 x 1000Base-T - RJ-45 , 1 x 1000Base-T - RJ-45 (WAN) , 1 x console - RJ-45
MTBF
58.9 years
FCC Class A certified, UL, TUV GS, C-Tick, BSMI, ICSA Firewall certified, cUL, ICSA Antivirus, CB, FIPS 140-2 Level 2, EMC, RoHS, WEEE, ANATEL, GOST-R, REACH, ICES Class A, KCC Class A, VPNC certified, LVD, IPv6 Ready, VCCI Class A, MSIP, CoC, UC APL
External power adapter
7.9 Watt
Power Provided
24 Watt
OS Provided
SonicOS 5.9.1.3
5 - 95% (non-condensing)
Scroll to top
