BT.com
Wishlist
SonicWALL Secure Upgrade Plus for TZ 400 - Subscription Licence (2 Years)
SonicWALL Secure Upgrade Plus for...
£1,085.36
Hurry, only 3 left in stock!
£1,085.36
Add to wishlist
Delivery
Standard 1-3 working days
Secure Upgrade Plus offers an upgrade path from current Dell SonicWALL products, as well as a trade-in path from competitors' products. This offer recognizes the past investments that customers have made and helps them maintain optimal security by letting them easily and affordably replace their existing security appliances.
Customers who purchase the complete set of subscription services and support when upgrading a Dell SonicWALL product or trading-in a competitive product can save up to 50% on the total annual cost of that solution, compared to the cost of buying the hardware separately and renewing services each year.
SonicWall TZ400 - security appliance
Security appliance
Bundled Services
2 years SonicWALL Comprehensive Gateway Security Suite
External
4 x 800 MHz
RAM
1 GB
Ports Qty
7
Ethernet, Fast Ethernet
Performance
Firewall throughput: 1.3 Gbps , Full Deep Packet Inspection (DPI) throughput: 300 Mbps , Application throughput: 900 Mbps , IPS throughput: 900 Mbps , Anti-malware throughput: 300 Mbps , Firewall throughput (IMIX): 500 Mbps , SSL inspection throughput: 100 Mbps , VPN throughput: 900 Mbps , Connection rate: 6000 connections per second
Virtual interfaces (VLANs): 50 , SSL VPN licences: 2 (maximum 100) , VPN tunnels (site-to-site): 20 , IPSec VPN clients: 2 (maximum 25) , SPI connections: 100000 , DPI connections: 90000 , Authenticated users (internal database): 150 , Single Sign-On (SSO) users: 500 , Manageable access points: 16
VoIP Protocols
SIP, H.323 v3, H.323 v4, H.323 v1, H.323 v2, H.323 v5
Pricing Type
SonicWALL Secure Upgrade Plus Program
19 cm x 13.4 cm x 3.5 cm
730 g
Security appliance
Bundled Services
19 cm
13.4 cm
3.5 cm
730 g
Processor / Memory / Storage
Processors Installed
4 x 800 MHz
RAM
1 GB
External
Ports Qty
7
Wired
Network / Transport Protocol
TCP/IP, PPTP, UDP/IP, L2TP, ICMP/IP, IPSec, PPPoE, DHCP
Routing Protocol
OSPF, RIP-1, RIP-2, BGP, static IP routing, policy-based routing (PBR)
Remote Management Protocol
SNMP 2, SNMP 3, HTTP, HTTPS, CLI
Performance
Firewall protection, VPN support, PAT support, VLAN support, Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, port mirroring, IPv6 support, antivirus analysis, Intrusion Prevention System (IPS), URL filtering, deep inspection, DDos attack prevention, Wi-Fi Multimedia (WMM) support, anti-spam protection, anti-malware protection, Quality of Service (QoS), Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T), DHCP server, bandwidth control, Common Access Card (CAC) reader support, anti-spyware protection, DHCP relay, 3G/4G USB Dongle Support, NetFlow, DiffServ Code Point (DSCP) support, Single Sign-On (SSO) support, anti-virus protection, keyword filtering
Encryption Algorithm
DES, Triple DES, MD5, SHA-1, 128-bit AES, 192-bit AES, 256-bit AES
Authentication Method
RADIUS, LDAP, internal user database, Active Directory, XAUTH authentication
IP Telephony
VoIP Protocols
6 x 1000Base-T - RJ-45 , 1 x 1000Base-T - RJ-45 (WAN) , 1 x USB 3.0 - Type A , 1 x console - RJ-45
MTBF
27 years
FCC Class A certified, UL, TUV GS, C-Tick, BSMI, ICSA Firewall certified, cUL, ICSA Antivirus, CB, FIPS 140-2 Level 2, EMC, RoHS, WEEE, ANATEL, GOST-R, REACH, ICES Class A, KCC Class A, VPNC certified, LVD, IPv6 Ready, VCCI Class A, MSIP, CoC, UC APL
Pricing Type
External power adapter
9.2 Watt
Power Provided
24 Watt
OS Provided
SonicOS 6.2.x
5 - 95% (non-condensing)
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.70
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.30
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£20.20
£14.67
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£27.14
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£18.52
C2G USB 2.0 To Fast Ethernet Adapter
Quicklinx: 7BBC | In Stock
£23.55
C2G USB Superbooster Extender Kit
Quicklinx: 7H7B | In Stock
£37.30
£37.98
Scroll to top
