BT.com
Wishlist
SonicWALL NSA 3500 TotalSecure (1YR)
SonicWALL NSA 3500 TotalSecure...
£4,870.27
£4,870.27
Add to wishlist
Delivery
Standard Due date unavailable
Dell SonicWALL NSA 3500 is a next generation United Threat Management firewall, utilizing a breakthrough multi-core hardware design with 4 cores and 6 Gigabit Ethernet interfaces to deliver real-time internal and external network protection without compromising network performance for corporate, branch office and distributed environments. The NSA 3500 combines high-speed intrusion prevention, file and content inspection and powerful application firewall capabilities with an extensive array of advanced networking and configuration flexibility features in an accessible, affordable platform that is easy to deploy and manage in a wide variety of environments.
SonicWall NSA 3500 - security appliance - with 1 year TotalSecure
Security appliance
Bundled Services
1 year TotalSecure
External - 1U
RAM
512 MB
Ports Qty
6
Performance
Firewall throughput: 1 Gbps , VPN throughput (3DES/AES): 650 Mbps , Intrusion prevention throughput: 220 Mbps , Gateway anti-virus throughput: 310 Mbps , Firewall throughput (IMIX): 440 Mbps , Connection rate: 5000 connections per second
VPN client licences: 250 , VPN tunnels (site-to-site): 800 , Nodes: unlimited , Connection / user qty: 128000 , Authenticated users (internal database): 500
VoIP Protocols
SIP, H.323 v3, H.323 v4, H.323 v1, H.323 v2
512 MB CompactFlash Card
Microsoft Windows 2000, Microsoft Windows Vista / XP
43.2 cm x 33.7 cm x 4.4 cm
5.1 kg
Security appliance
Bundled Services
1 year TotalSecure
Height (Rack Units)
1U
43.2 cm
33.7 cm
4.4 cm
5.1 kg
Processor / Memory / Storage
RAM
512 MB
External
Ports Qty
6
Wired
Data Transfer Rate
1 Gbps
Network / Transport Protocol
TCP/IP, PPTP, UDP/IP, L2TP, ICMP/IP, IPSec, PPPoE, DHCP
Routing Protocol
OSPF, RIP-1, RIP-2, static IP routing
Remote Management Protocol
SNMP 2, HTTP, HTTPS
Performance
Firewall protection, DHCP support, load balancing, Syslog support, DoS attack prevention, dynamic DNS server, antivirus analysis, High Availability, Intrusion Prevention System (IPS), Stateful Failover, anti-spam protection, Quality of Service (QoS), Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T)
Encryption Algorithm
DES, Triple DES, MD5, IKE, SHA-1, PKI, 128-bit AES, 192-bit AES, 256-bit AES
Authentication Method
Secure Shell (SSH), RADIUS, X.509 certificates, LDAP, internal user database, Active Directory
IEEE 802.1Q, X.509
IP Telephony
VoIP Protocols
6 x 1000Base-T - RJ-45 , 1 x management , 2 x USB
FCC Class A certified, UL, TUV, VCCI, BSMI, cUL, ICES-003, CB, CCC, PSB, RoHS
Internal power supply
64 Watt
Power Provided
180 Watt
OS Provided
SonicOS Enhanced
Software Included
SonicWALL ViewPoint
Virus definitions update - 1 year , E-mail database update - 1 year , Intrusion definitions update - 1 year
5 °C
10 - 90%
Other bundles
£4,870.27
C2G 2m Cat5e Cable with Homeplug
Save £2.00
£4,873.75
Scroll to top
