BT.com
Wishlist
SonicWALL NSA 250M Wireless-N International
Delivery
Standard Due date unavailable
Dell SonicWALL NSA Wireless-N high-performance, modular next-generation firewall offers branch offices and distributed enterprises in-depth frontline security, application and user control, network productivity and optional 802.11 dual-band wireless. The NSA 250M acts as the first line of network defense against viruses, Trojans, key-loggers and other application layer attacks, without compromising network performance. The NSA 250M series can be extended with a variety of modules to provide deployment flexibility and reduce acquisition and maintenance costs.
The NSA 250M series offers an extensive array of advanced networking and configuration flexibility features in an accessible, affordable platform that is easy to deploy and manage in a wide variety of environments.
SonicWALL NSA 250M Wireless-N - security appliance
Security appliance
External - 1U
RAM
512 MB
Flash Memory
32 MB
Ports Qty
5
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz, 5 GHz
Performance
Stateful throughput: 750 Mbps , Gateway anti-virus throughput: 140 Mbps , IPS throughput: 250 Mbps , Full Deep Packet Inspection (DPI) throughput: 130 Mbps , Firewall throughput (IMIX): 210 Mbps , VPN throughput (3DES/AES): 200 Mbps
Connection / user qty: 110000 , DPI connections: 64000 , New sessions per second: 3000 , Authenticated users (internal database): 150 , Virtual interfaces (VLANs): 35 , VPN tunnels (site-to-site): 50
VoIP Protocols
SIP, H.323 v3, H.323 v4, H.323 v1, H.323 v2, H.323 v5
26.7 cm x 18.1 cm x 3.8 cm
1.43 kg
Security appliance
Height (Rack Units)
1U
26.7 cm
18.1 cm
3.8 cm
1.43 kg
Processor / Memory / Storage
RAM
512 MB
Flash Memory
32 MB
External
Ports Qty
5
Wireless, wired
Data Transfer Rate
1 Gbps
Network / Transport Protocol
TCP/IP, PPTP, UDP/IP, L2TP, ICMP/IP, IPSec, PPPoE, DHCP
Routing Protocol
OSPF, RIP-1, RIP-2, static IP routing, policy-based routing (PBR)
Remote Management Protocol
SNMP 2, HTTP, HTTPS, SSH, CLI
Frequency Band
2.4 GHz, 5 GHz
Performance
Firewall protection, DHCP support, VPN support, load balancing, Syslog support, DoS attack prevention, content filtering, dynamic DNS server, IPv6 support, antivirus analysis, High Availability, Intrusion Prevention System (IPS), deep inspection, Stateful Failover, DDos attack prevention, Stateful switchover (SSO), MIMO technology, anti-spam protection, Quality of Service (QoS), Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T), DHCP server
Encryption Algorithm
DES, Triple DES, MD5, IKE, SHA-1, PEAP, TTLS, TKIP, WPA, WPA2, WPA-PSK, PKI, 128-bit AES, 192-bit AES, 256-bit AES, WPA2-PSK
Authentication Method
Secure Shell (SSH), RADIUS, X.509 certificates, LDAP, internal user database, Active Directory, Extensible Authentication Protocol (EAP), XAUTH authentication
IEEE 802.3, IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, X.509, IEEE 802.11i, IEEE 802.11n
IP Telephony
VoIP Protocols
IP Telephony Features
VoIP gatekeeper support, VoIP outbound bandwidth management
Aerial
Antenna
External detachable
Antenna Qty
3
Communications
Supported Flash Memory Cards
CompactFlash Card
Expansion Slots
1 (total) / 1 (free) x expansion slot
5 x 1000Base-T - RJ-45 , 1 x management , 2 x USB - Type A
MTBF
14 years
FCC Class A certified, UL, TUV GS, VCCI, C-Tick, cUL, NOM, CB, MIC, RoHS, FIPS 140-2, WEEE, EAL 4+
Internal power supply
16 Watt
Power Provided
36 Watt
OS Provided
SonicOS
5 - 95% (non-condensing)
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.76
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.42
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£22.05
£15.39
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£29.59
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£20.19
C2G USB Superbooster Extender Kit
Quicklinx: 7H7B | In Stock
£37.30
£59.58
Scroll to top
