BT.com
Wishlist
SonicWALL NSA 2400 High Availability (HA) Unit
SonicWALL NSA 2400 High...
£1,334.66
£1,334.66
Add to wishlist
Delivery
Standard Due date unavailable
The Dell SonicWALL NSA 2400 is a next-generation Unified Threat Management platform, utilizing a breakthrough multi-core hardware design with 2 cores and 6 Gigabit Ethernet interfaces to deliver real-time network protection without compromising performance. Ideal for small-to-midsize corporate and branch office environments, the NSA 2400 offers best-in-class threat prevention, rapid deployment and lowered TCO. The NSA 2400 combines high-speed intrusion prevention, file and content inspection and powerful application firewall capabilities with an extensive array of advanced network and configuration flexibility features in an accessible, affordable platform that is easy to deploy and manage in a wide variety of environments.
SonicWall NSA 2400 High Availability - security appliance
Security appliance
External - 1U
RAM
256 MB
Ports Qty
6
Performance
Firewall throughput: 450 Mbps , VPN throughput (3DES/AES): 300 Mbps , Intrusion prevention throughput: 50 Mbps , Gateway anti-virus throughput: 100 Mbps , Firewall throughput (IMIX): 225 Mbps , Connection rate: 3000 connections per second
VPN client licences: 10 , VPN tunnels (site-to-site): 75 , Nodes: unlimited , Connection / user qty: 48000 , Authenticated users (internal database): 250
VoIP Protocols
SIP, H.323 v3, H.323 v4, H.323 v1, H.323 v2
512 MB CompactFlash Card
Microsoft Windows 2000, Microsoft Windows Vista / XP
43.2 cm x 26 cm x 4.4 cm
3.7 kg
Security appliance
Height (Rack Units)
1U
43.2 cm
26 cm
4.4 cm
3.7 kg
Processor / Memory / Storage
RAM
256 MB
External
Ports Qty
6
Wired
Data Transfer Rate
1 Gbps
Network / Transport Protocol
TCP/IP, PPTP, UDP/IP, L2TP, ICMP/IP, IPSec, PPPoE, DHCP
Routing Protocol
OSPF, RIP-1, RIP-2, static IP routing
Remote Management Protocol
SNMP 2, HTTP, HTTPS
Performance
Firewall protection, DHCP support, load balancing, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, dynamic DNS server, antivirus analysis, High Availability, Intrusion Prevention System (IPS), deep inspection, Stateful Failover, DDos attack prevention, anti-spam protection, Quality of Service (QoS), Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T)
Encryption Algorithm
DES, Triple DES, MD5, IKE, SHA-1, PKI, 128-bit AES, 192-bit AES, 256-bit AES
Authentication Method
Secure Shell (SSH), RADIUS, X.509 certificates, LDAP, internal user database, Active Directory
IEEE 802.1Q, X.509
IP Telephony
VoIP Protocols
Communications
Supported Flash Memory Cards
CompactFlash Card
6 x 1000Base-T - RJ-45 , 1 x management , 2 x USB
Internal power supply
Installed Qty
1
42 Watt
Power Provided
180 Watt
OS Provided
SonicOS Enhanced
Software Included
SonicWALL ViewPoint
5 °C
10 - 90%
Scroll to top
