BT.com
Wishlist
SonicWALL Dell SonicWALL Secure Upgrade Plus for TZ 500 - Subscription Licence (2 Years)
SonicWALL Dell SonicWALL Secure...
£1,678.56
£1,678.56
Add to wishlist
Delivery
Standard Due date unavailable
Expand, control and protect your network. A fast connection to your business, school, remote office or retail site is only half the story; you also need to be able to securely manage it. The TZ500 gives you enterprise-grade protection to stop cyberattacks as you expand and control your network. The TZ500 offers a no-compromise approach to securing growing networks. For distributed enterprises with remote offices, all TZ products can be managed by the central office using a larger SonicWALL firewall and GMS.
SonicWall TZ500 - security appliance - with 2 years SonicWALL Comprehensive Gateway Security Suite
Security appliance
Bundled Services
External
4 x 1 GHz
RAM
1 GB
Ports Qty
8
Performance
Firewall throughput: 1.4 Gbps , Full Deep Packet Inspection (DPI) throughput: 400 Mbps , Application throughput: 1 Gbps , IPS throughput: 1 Gbps , Anti-malware throughput: 400 Mbps , Firewall throughput (IMIX): 700 Mbps , SSL inspection throughput: 150 Mbps , VPN throughput: 1 Gbps , Connection rate: 8000 connections per second
Virtual interfaces (VLANs): 50 , SSL VPN licences: 2 (maximum 150) , VPN tunnels (site-to-site): 25 , IPSec VPN clients: 2 (maximum 25) , SPI connections: 125000 , DPI connections: 100000 , Authenticated users (internal database): 250 , Single Sign-On (SSO) users: 500 , Manageable access points: 16
VoIP Protocols
SIP, H.323 v3, H.323 v4, H.323 v1, H.323 v2, H.323 v5
Pricing Type
SonicWALL Secure Upgrade Plus Program
22.5 cm x 15 cm x 3.5 cm
915 g
Security appliance
Bundled Services
22.5 cm
15 cm
3.5 cm
915 g
Processor / Memory / Storage
Processors Installed
4 x 1 GHz
RAM
1 GB
External
Ports Qty
8
Wired
Network / Transport Protocol
TCP/IP, PPTP, UDP/IP, L2TP, ICMP/IP, IPSec, PPPoE, DHCP
Routing Protocol
OSPF, RIP-1, RIP-2, BGP, static IP routing, policy-based routing (PBR)
Remote Management Protocol
SNMP 2, SNMP 3, HTTP, HTTPS, CLI
Performance
Firewall protection, VPN support, PAT support, VLAN support, Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, port mirroring, IPv6 support, antivirus analysis, Intrusion Prevention System (IPS), URL filtering, deep inspection, DDos attack prevention, Wi-Fi Multimedia (WMM) support, anti-spam protection, anti-malware protection, Quality of Service (QoS), Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T), DHCP server, bandwidth control, Common Access Card (CAC) reader support, anti-spyware protection, DHCP relay, 3G/4G USB Dongle Support, NetFlow, DiffServ Code Point (DSCP) support, Single Sign-On (SSO) support, anti-virus protection, keyword filtering
Encryption Algorithm
DES, Triple DES, MD5, SHA-1, 128-bit AES, 192-bit AES, 256-bit AES
Authentication Method
RADIUS, LDAP, internal user database, Active Directory, XAUTH authentication
IP Telephony
VoIP Protocols
7 x 1000Base-T - RJ-45 , 1 x 1000Base-T - RJ-45 (WAN) , 2 x USB 3.0 - Type A , 1 x console - RJ-45
MTBF
20 years
FCC Class A certified, UL, TUV GS, C-Tick, BSMI, ICSA Firewall certified, cUL, ICSA Antivirus, CB, FIPS 140-2 Level 2, EMC, RoHS, WEEE, ANATEL, GOST-R, REACH, ICES Class A, KCC Class A, VPNC certified, LVD, IPv6 Ready, VCCI Class A, MSIP, CoC, UC APL
Pricing Type
External power adapter
13.4 Watt
Power Provided
36 Watt
OS Provided
SonicOS 6.2.x
5 - 95% (non-condensing)
Scroll to top
