BT.com
Wishlist
Somfy One with Alarm System
£348.99
£348.99
Add to wishlist
Delivery
Standard 1-3 working days
With Somfy One+, you'll have everything you need in one go when it comes to your security. Install it in a strategic spot, activate it using the Somfy Protect app, and voilĂ ! If the camera detects movement, the alarm goes off, you get a push message on your smartphone, and you can see what's going on live. What if you're not reachable? You can add other people using the app who will then receive a push message if there's something suspicious going on. Pets? Somfy One takes that into account. Your privacy? As soon as you enter the room, the camera shutter closes.
Somfy ONE+ - network surveillance camera
Network surveillance camera
Audio Support
Yes: built-in speaker, built-in microphone
Wireless
9 cm
9 cm
11 cm
260 g
Camera
Colour - Day&Night - fixed
Video Modes
1080p
Digital Zoom
8
Frame Rate
30 frames per second
Remote control, door/window sensor
45 °C
Scroll to top
