BT.com
Wishlist
Smart Technologies SPNL-4075 75" Interactive Flat Panel 10 Point Touch
Smart Technologies SPNL-4075 75"...
£4,459.54
£4,459.54
Add to wishlist
Delivery
Standard 1-3 working days
The accurate, natural, and responsive touch experience from corner to corner. Fingers glide effortlessly over the surface, providing hours of error-free use in perfect comfort. Writing is natural and looks better with SMART ink. Whether you're using a pen or finger, each stroke is a work of art. Its realistic digital ink improves legibility, so teachers don't have to re-write and students feel confident contributing.
SMART Board 4075 75" LED display
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
75"
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Voltage
350 Watt
172.5 cm x 16.3 cm x 100.4 cm
86 kg
2 years warranty
350 Watt
Diagonal Class
75"
Combined with
Touchscreen
TV Tuner
No tuner
172.5 cm
16.3 cm
100.4 cm
86 kg
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
4000:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Touchpoints Qty
10
Response Time
6 ms
Infrared multitouch technology
Stands & Mounts
Flat Panel Mount Interface
1000 x 600 mm
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Connector Type
3 x HDMI input - bottom , Audio line-out - bottom , Audio line-in - bottom , USB 2.0 - bottom , USB 2.0 - bottom , Composite video/audio input - bottom , Component video input - bottom , VGA input - bottom , SPDIF output - bottom , HDMI input - side , USB 2.0 - side
2 touch pens, pen tray, SMART Notebook software
USB cable - 5 m , VGA cable - 1.8 m
UL, cUL, IC, FCC, RoHS, WEEE, REACH, RCM
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Width (Shipping)
184.2 cm
Depth (Shipping)
28 cm
Height (Shipping)
128.5 cm
Weight (Shipping)
110 kg
5 °C
35 °C
10 - 80% (non-condensing)
Scroll to top
