BT.com
Wishlist
Smart Technologies SPNL-4055 55" Interactive Flat Panel 8 Touch Points 16:9
Smart Technologies SPNL-4055 55"...
£1,822.60
£1,822.60
Add to wishlist
Delivery
Standard Due date unavailable
No matter the teaching style or classroom environment, give students the best in collaboration technology. Whether you need a front-of-room display or one for individual and group work, the 4000 series is the future of teaching, learning and collaborating.
SMART Board 4055 55" LED display
LED-backlit LCD flat panel display with touch-screen
Diagonal Class
55"
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
Component, composite, HDMI
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15)
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Voltage
125 Watt
129.2 cm x 18.8 cm x 77.4 cm
53 kg
2 years warranty
125 Watt
Diagonal Class
55"
Combined with
Touch-screen
TV Tuner
No tuner
Video Interface
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15)
129.2 cm
18.8 cm
77.4 cm
53 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
1400:1
Brightness
300 cd/m²
Viewing Angle
178 degrees
Pixel Pitch
0.630 mm
Response Time
8 ms
Infrared multitouch technology
Stands & Mounts
Flat Panel Mount Interface
600 x 400 mm
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Connector Type
3 x HDMI input , VGA input , Component video/audio input , Composite video/audio input , Digital audio output (optical) , USB , USB , Audio line-in
2 touch pens, pen tray, SMART Notebook software
USB cable - 5 m , VGA cable - 1.8 m
UL, cUL, IC, FCC, RoHS, WEEE, REACH, ERP
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Width (Shipping)
138.5 cm
Depth (Shipping)
28 cm
Height (Shipping)
102.5 cm
Weight (Shipping)
60 kg
5 °C
35 °C
10 - 80% (non-condensing)
Scroll to top
