BT.com
Wishlist
Smart Technologies SP518 Podium with Notebook
Delivery
Standard Due date unavailable
Create engaging presentations and dynamic collaboration sessions with the SMART Podium 500 series interactive pen display. You can display, interact with and write over digital content on SMART Podium, all while displaying that content on a larger screen in the same room or from a remote location.
The versatile interactive pen display works as a powerful presentation tool and supports collaboration in virtually any learning space, from small classrooms or labs to large auditoriums. Open presentations, documents, applications, websites and multimedia files, write notes over them in digital ink and save your work for distribution or later reference. In rooms equipped with SMART Board interactive whiteboards or displays, you can work with content from anywhere in the room and display it on the interactive whiteboard or display. And in distance education scenarios, teachers and students can share screens using SMART Bridgit conferencing software and mark up documents and files as if they were in the same room.
With the SMART Podium interactive pen display, you can create and deliver engaging, interactive, digital presentations. Because your course material is in front of you and displayed on a large screen, you can focus on keeping students engaged. The display's tethered pen acts as a mouse to navigate content on your screen - control computer applications and write notes in multiple digital ink colors over applications, slides, websites and videos. The Smooth Tilt Stand helps support a natural writing posture. The intuitive function buttons - illuminated for dimly lit rooms - enable you to change ink colors, erase, highlight and emphasize content, access the mouse function, and save and share your work.
SMART Podium interactive pen display SP518-NB - LCD monitor - 18.5"
LCD monitor - 18.5"
Digital pen, USB 2.0 hub
Aspect Ratio
Widescreen - 16:9
Native Resolution
HD 1366 x 768
Brightness
180 cd/m²
Contrast Ratio
580:1
Response Time
5 ms
Colour Support
16.8 million colours
Input Connectors
DVI-I
Display Position Adjustments
Tilt
46.7 cm x 7.6 cm x 33 cm
UL, TUV GS, C-Tick, NOM, SASO, CB, CCC, PSB, FCC, IRAM, RoHS, WEEE, GOST-R
2 years warranty
Display Type
LCD monitor / TFT active matrix
Diagonal Size
18.5"
Viewable Size
18.5"
Built-in Devices
USB 2.0 hub
Aspect Ratio
Widescreen - 16:9
Native Resolution
HD 1366 x 768
Brightness
180 cd/m²
Contrast Ratio
580:1
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 Hz
Horizontal Refresh Rate
76 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
HDCP
46.7 cm x 7.6 cm x 33 cm - without stand
Input
Digital pen
Movement Detection Technology
Digital vision touch
DVI-I , DVI-I , USB 2.0 upstream (Type B) , 3 x USB 2.0 downstream
Mechanical
Tilt
Tilt Angle
46.5
Flat Panel Mount Interface
100 x 100 mm
Digital pen
1 x DVI cable , 1 x DVI-VGA cable , 1 x USB cable
Backlight Life
30,000 hours
Power Supply
External
Included Software
SMART Notebook
Apple MacOS, Microsoft Windows
Dimensions & Weight Details
With stand - width: 46.7 cm - depth: 29.8 cm - height: 32.1 cm - weight: 8.9 kg , Without stand - width: 46.7 cm - depth: 7.6 cm - height: 33 cm
5 °C
35 °C
20 - 80% (non-condensing)
Scroll to top
