BT.com
Wishlist
Smart Technologies SMS Flatscreen x stand
Smart Technologies SMS Flatscreen x...
£600.00
£600.00
Add to wishlist
Delivery
Standard 1-3 working days
This is a very flexible solution mounted on wheels that allows the screen to be rotated from a vertical to a horizontal position after mounting. The bracket is easy to add shelves and cabinets for DVDs and other peripherals.
SMS Flatscreen X FH M1455 - stand
Stand - floor-standing
88.3 cm x 69.1 cm x 162 cm
Tilt
Recommended Use
LCD / plasma panel
Recommended Display Size
40" - 60"
Flat Panel Mount Interface
200 x 200 mm, 800 x 400 mm
Max Load Weight
50 kg
White, aluminium
5 years warranty
88.3 cm
69.1 cm
162 cm
White, aluminium
AV Furniture
Stand
Recommended Use
LCD / plasma panel
Placing / Mounting
Floor-standing
40" - 60"
Tilt
Max Load Weight
50 kg
Wheels
5 years warranty
Service & Support Details
Limited warranty - 5 years
Scroll to top
