BT.com
Wishlist
Smart Technologies SMART Board 4065 Interactive Flat Panel
Delivery
Standard Due date unavailable
Designed specifically for classrooms, the SMART Board 4065 interactive flat panel combines a premium touch experience with the power of SMART Notebook collaborative learning software on a 65" display. The high-definition, shadow-free 65" (164.5 cm) LED display features lowfriction coated glass that enables fingers to glide smoothly over the surface, facilitating a natural touch experience.
The SMART Board 4065 interactive flat panel also virtually eliminates glare and provides an optimal view from any angle in the classroom, delivering an unparalleled viewing and writing experience to offer the best value for classrooms. The multi-touch interactive flat panel features freestyle multi-user interaction anywhere on the display, enabling students to collaborate without limitations.
SMART Board 4065 65" LED display
LED-backlit LCD flat panel display with touch-screen
Diagonal Class
65"
Resolution
1920 x 1080
Display Format
1080p (Full HD)
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Voltage
175 Watt
151 cm x 19.2 cm x 90 cm
69.4 kg
2 years warranty
175 Watt
Diagonal Class
65"
Combined with
Touch-screen
TV Tuner
No tuner
151 cm
19.2 cm
90 cm
69.4 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
4000:1
Brightness
300 cd/m²
Viewing Angle
178 degrees
Pixel Pitch
0.744 mm
Response Time
6.5 ms
Infrared multitouch technology
Stands & Mounts
Flat Panel Mount Interface
600 x 400 mm
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Connector Type
3 x HDMI input , USB , Audio line-in , USB , Component video/audio input , Composite video/audio input , Serial , VGA input , SPDIF output
2 touch pens, pen tray, SMART Notebook software
USB cable - 5 m , VGA cable - 1.8 m
UL, cUL, IC, FCC, RoHS, WEEE, REACH, ERP
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Width (Shipping)
161 cm
Depth (Shipping)
28 cm
Height (Shipping)
115 cm
Weight (Shipping)
90 kg
10 °C
10 - 80% (non-condensing)
Scroll to top
