BT.com
Wishlist
Smart Technologies Large Fusion Micro-Adjustable Fixed Wall Display Mount 37"
Smart Technologies Large Fusion...
£150.00
More than 50 in stock
£150.00
Add to wishlist
Delivery
Standard 1-3 working days
Chief upgraded fixed wall mounts based on installer feedback and direct observations of installers in the field. Many features join Fusion favorites like Centerless shift, ControlZone leveling adjustment and ClickConnect latching.
The benefits included added stability, faster install, improved lateral shift, easier cable management and enhanced security.
Installer-inspired Fusion fixed mount solves top flat panel installation problems, offering flexible adjustments for large displays with a low-profile display mounting solution.
Chief Large FUSION LSM1U - wall mount
Wall mount
88.3 cm x 5.1 cm x 46.4 cm
Recommended Use
LCD / plasma panel
Recommended Display Size
37"-63"
Max Mounting Pattern Size
871 x 400 mm
Max Load Weight
91 kg
Mounting Stud Centers
32", 16"
88.3 cm
5.1 cm
46.4 cm
AV Furniture
Wall mount
Mounting Components
Wall mount
Recommended Use
LCD / plasma panel
871 x 400 mm
32", 16"
37"-63"
Max Load Weight
91 kg
Fixed, lateral shift, ClickConnect Technology, Controlzone Leveling, Centreless Shift, Centris Low-Profile Tilt
Scroll to top
