BT.com
Wishlist
Smart Technologies kapp iQ 65" All in One Ultra HD 4K Display and Bluetooth Interactive Whiteboard
Smart Technologies kapp iQ 65" All...
£4,687.50
15 in stock
£4,687.50
Add to wishlist
Delivery
Standard 1-3 working days
THE INTERACTIVE DISPLAY REIMAGINED
The only multi-way, interactive display that combines the simplicity of a traditional whiteboard with the power of an Ultra HD display.
MEET kapp iQ™
Imagine an Ultra HD display with a built-in whiteboard that enables multi-way inking between any combination of devices, anywhere in the world - simultaneously. Sound magical? We thought so too.
SMART kapp iQ lets everyone, whether in the meeting room or classroom, see what is being written in real time. But it doesn't stop there. Every participant can contribute to the display from their device. When they do, their writing instantly appears on the display and on everyone else's device.
It's true multi-way collaboration, where work can be saved at any time to a storage service, like Evernote™.
Imagine the possibilities.
Whiteboard meets display
SMART kapp iQ isn't just a whiteboard. It's the world's best Ultra HD enabled display and includes:
Silktouch™ technology
The most accurate, natural, and responsive touch experience from corner to corner.
Pen iQ™
Write independently and simultaneously, using differently colored digital ink.
Object awareness™
The display differentiates between a finger, pen or palm, so you can touch, write and erase naturally.
Ultra HD resolution
Commercial-grade, glare-free LED panels brilliantly display detailed content, as well as support HD and SD content.
Multi-way sharing
All remote participants can write on the display in real-time from any device. Different ink colors make ideas come alive and help identify contributions.
Display-to-device
Connect any Android or iOS device to SMART kapp iQ and you can share and save in real time to any connected laptop, tablet, smartphone or other SMART kapp iQ display.
Connect using the SMART kapp app
Connect with the display through the SMART kapp app in a single step using a QR code. Only one person needs to connect. Once you're connected, share the meeting with participants in the room or across the globe for multi-way sharing, capturing and saving.
Display-to-display
Host live sessions between multiple SMART kapp iQ displays across remote locations. Anything written or shared on SMART kapp iQ is viewable on connected displays, and participants are able to share right back.
Sizing options
SMART kapp iQ is available in two popular sizes: 55" and 65" (diagonal), perfect for presenting or collaborating in meeting rooms, break out spaces, offices, lecture halls or classrooms.
Quick install
Plug it in and let the brainstorming begin. Installation is quick and easy, with no IT integration required.
Auto startup
SMART kapp iQ powers-up automatically thanks to state-of-the-art Proximity Detection that can instantly sense the presence of users. No cables or remotes, and no wasted time.
Up to 250 participants
After you connect, a URL is immediately created for your session. Send the link to whomever you'd like to have join, and they'll see the content on their display as it unfolds on kapp iQ. Up to 250 participants may join a session with the SMART kapp Plus subscription.
Save and share notes
Any participant can capture and save notes as snapshots (JPEG or PDF), and store them within the app or on Evernote™ for archival and easy distribution.
Data security by design
Any content you share live via the session URL is deleted when you disconnect from the display. With the Plus app, your organization gains the added protection of a secure PIN code for each session.
THE PERFECT FIT FOR ANY SETTING
Business collaboration? Training session? Remote brainstorm? Classroom engagement? SMART kapp iQ offers two different models, accommodating any space so no matter where your coworkers, clients or students are located, everyone can engage and collaborate together.
SMART kapp IQ 65 - interactive whiteboard - Bluetooth 4.0
Interactive whiteboard
Diagonal Size
65"
Installation Type
Wall mountable
Wireless - Bluetooth 4.0
Display
LCD display - 64" - 3840 x 2160
150.8 cm x 12 cm x 97.8 cm
62.4 kg
Movement Detection Technology
Digital vision touch
Digital Vision Touch (DViT) technology
Apple iOS 7.1 or later, Android 4.4.4 (KitKat)
150.8 cm
12 cm
97.8 cm
62.4 kg
Input Device
Wireless
Bluetooth 4.0
Active Area
142.8 cm x 80.4 cm
Display
LCD display
Diagonal Size
64"
Image Aspect Ratio
16:9
Pixel Pitch
0.372 mm
Native Resolution
3840 x 2160
Image Brightness
360 cd/m²
Image Contrast Ratio
1400:1
Vertical Refresh Rate
24 - 120 Hz
Horizontal Refresh Rate
244 - 280 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Response Time
8 ms
Board
Diagonal Size
65"
Installation Type
Wall mountable
Additional Ports
1 x USB 2.0 - 4 pin USB Type B , 1 x HDMI input , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 input , 1 x USB 2.0 - 4 pin USB Type A
UL, IC, FCC, RoHS, WEEE, REACH, RCM
System Requirements Details
Apple iOS 7.1 or later - HD 50 MB , RAM 1024 MB - HD 50 MB
5 °C
35 °C
10 - 80% (non-condensing)
Scroll to top
