BT.com
Wishlist
Smart Technologies Interactive Flat panel 4 Touch points 16:9 5 Yr OSW for Edu
Smart Technologies Interactive Flat...
£5,475.24
£5,475.24
Add to wishlist
Delivery
Standard Due date unavailable
The most accurate, natural, and responsive touch experience from corner to corner. Fingers glide effortlessly over the surface, providing hours of error-free use in perfect comfort. Students can see their contributions free from interruption by their partner. Using different colored ink, you can write independently and simultaneously in any lesson activity to open new collaborative opportunities.
SMART Board 6075 75" LED display
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
75"
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
DisplayPort
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Voltage
350 Watt
173.1 cm x 12 cm x 110.2 cm
84 kg
2 years warranty
350 Watt
Diagonal Class
75"
Combined with
Touchscreen
TV Tuner
No tuner
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
DisplayPort
173.1 cm
12 cm
110.2 cm
84 kg
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
1200:1
Brightness
360 cd/m²
Viewing Angle
178 degrees
Touchpoints Qty
4
Response Time
12 ms
Optical Touch technology
Stands & Mounts
Flat Panel Mount Interface
600 x 400 mm
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Connector Type
2 x HDMI input - side , 3 x USB 2.0 - side , Audio line-out - side , DisplayPort - side , Serial , USB 2.0 - bottom
2 touch pens, SMART Notebook software
USB cable - 5 m
UL, VCCI, EMC, IC, FCC, RoHS, WEEE, PSE Mark, REACH, KC
Power supply
Nominal Voltage
Power Consumption Stand by
1.7 Watt
Width (Shipping)
191.6 cm
Depth (Shipping)
35.5 cm
Height (Shipping)
138 cm
Weight (Shipping)
108 kg
5 °C
35 °C
5 - 80% (non-condensing)
Scroll to top
