BT.com
Wishlist
Smart Technologies 55" SMART Board® 6055 4K UHD HDMI USB + 3 Year Advantage
Smart Technologies 55" SMART Board®...
£2,773.48
Select:
£2,773.48
Add to wishlist
Delivery
Standard Due date unavailable
Overview
The SMART Board® 6055 interactive flat panel features SMART's proprietary DViT® (Digital Vision Touch) technology and combines a premium touch experience with the power of SMART Notebook® collaborative learning software on a 54 1/2" (138.4 cm) LED display.
The 4K ultra-high-definition resolution display provides optimal image clarity and viewing from any angle. With the new Pen iQ feature, you can assign different ink appearances to either pen and write or draw over any application in digital ink.
With Object Awareness, you can perform mouse functions with your finger, write in digital ink with the pen, and erase with your palm or eraser -- all without switching tools or modes. You can also use an array of gestures in applications. Two users can write or draw at the same time
SMART Board 6055 - interactive whiteboard - USB
Interactive whiteboard
Wired - USB
Display
LCD display - 3840 x 2160
129 cm x 12 cm x 85.4 cm
47.4 kg
Sound
Speakers
Built-in stereo speakers, multi-touch board
AC 120/230 V
129 cm
12 cm
85.4 cm
47.4 kg
Input Device
Wired
USB
Active Area
121 cm x 68 cm
Display
LCD display
Image Aspect Ratio
16:9
Pixel Pitch
0.315 mm
Native Resolution
3840 x 2160
Image Brightness
360 cd/m²
Vertical Refresh Rate
24 - 120 Hz
Horizontal Refresh Rate
244 - 280 kHz
Sound
Speakers
Output Power / Channel
10 Watt
1 x USB 2.0 - 4 pin USB Type B , 2 x video - HDMI input - 19 pin HDMI Type A , 1 x audio - output - mini-phone stereo 3.5 mm , 1 x management - RS-232
2 interactive pens, USB cable (5 m)
RoHS, WEEE, REACH
AC 120/230 V
Power Consumption
110 Watt
Power Consumption Stand by
15 Watt
Software Included
SMART Board, SMART Notebook
Sound Emission
35 dBA
5 °C
35 °C
5 - 80% (non-condensing)
Scroll to top
