BT.com
Wishlist
Sigma 70-300mm f/4-5.6 DG Macro - Nikon AF Fit Lens
Sigma 70-300mm f/4-5.6 DG Macro -...
£164.24
33 in stock
£164.24
Add to wishlist
Delivery
Standard 1-3 working days
The 70-300mm F4-5.6 DG MACRO for Nikon is a telephoto zoom lens with excellent value for money and optimized for use with digital SLR cameras. This telephoto lens has a 1:2 maximum magnification at the 300mm focal length. It is ideal for portraits, sport and other types of photography. SLD (Special Low Dispersion) glass provides excellent correction of chromatic aberration. The super multi-layer coating reduces flare and ghosting. High image quality is assured throughout the entire zoom range.
Sigma telephoto zoom lens - 70 mm - 300 mm
Lens System
Telephoto zoom lens
Intended For
35mm SLR, digital SLR
Mounting Type
Nikon F
Lens Aperture
F/4.0-5.6
Focal Length
70 mm - 300 mm
Optical Zoom
4.3 x
Min Focus Distance
95 cm
Focus Adjustment
Automatic, manual
Lens Construction
10 groups / 14 elements
Special Functions
Macro, tele, zoom
Filter Size
58 mm
Length
12 cm
0.55 kg
Length
12 cm
Diameter
7.7 cm
0.55 kg
Lens System
Telephoto zoom lens
Special Functions
Macro, tele, zoom
Intended For
Focal Length
70 mm - 300 mm
Lens Aperture
F/4.0-5.6
Minimum Aperture
F/22
Optical Zoom
4.3 x
Magnification
1 / 2
Min Focus Distance
95 cm
Focus Adjustment
Automatic, manual
Zoom Adjustment
Manual
Max View Angle
34.3 degree(s)
Min View Angle
8.2 degree(s)
Lens Construction
Filter Size
58 mm
Diaphragm Blades
9
Lens Coating
Multicoated
Mounting Type
Nikon F
Dust cap, lens cap
Scroll to top
