Click to visit BT.com
BT.com
Wishlist
Shuttle XS36VL Intel Atom D2550 NM10 DDR3 Slim PC
Quicklinx: 8NNPWS00
Mfr#: XS36VL
Essential accessories
Fanless slim PC with two digital video outputs
XS36VL with low-energy Intel Atom D2550 processor is the successor of Shuttle's XS36V. It is just 36 mm thin and completely passively cooled - that means: it is not only quiet, but also virtually maintenance free. Three different monitor ports (HDMI, DVI-D, VGA) allow a flexible choice of screen types. In addition to Gigabit-LAN and 5x USB 2.0, this model also offers two RS-232 interfaces for professional applications (e.g. device control). With the optional PV03 mount, the XS36VL can also be fitted to VESA-compatible screens.
Intel chipset inside
Play it safe with the reliable chipsets from the world's largest chip manufacturer. Intel chipsets have proven themselves over many years, have been presented with awards by the trade press and offer the best possible degree of compatibility.
Intel Atom CPU platform
Atom epitomises an energy-saving, multi-functional CPU platform. Despite its low energy consumption, this highly integrated platform features a dual core processor with integrated graphics card. The computing power of this platform easily meets everyday office needs or the demands of more simple home applications.
Low energy consumption
Thrift is a virtue. In terms of power consumption this Mini-PC sets an example. It is not just good for the environment but for your pocket, too.
Fanless and whisper-quiet
The fanless technology used in this PC means it is incredibly quiet. Doing away with these mechanical components also reduces the number of wearing parts, making the machine more durable and stable.
You can rely on SSD
This is where an energy-saving "Solid State Drive" is put to use. This new drive technology guarantees extremely short access times, the highest data transmission rates and considerably lower energy consumption compared to conventional hard disks. SSDs have no mechanical components at all, are therefore subject to less wear and tear and consequently benefit from a longer service life.
Multiformat card reader
At last - no more searching for missing digital camera leads. Simply insert the memory card and you can access all stored photos and videos immediately.
Anti-theft protection
The Kensington Lock forms part of the anti-theft system. As with many other Notebooks, this Mini-PC can also be safely locked, ensuring long-term enjoyment from your Shuttle product.
Fan-less external power supply
A highly effective external power supply provides the Shuttle Mini-PC with its energy. And since it works without a fan, it is completely noise-free.
Connections without all those annoying cables
Data is transferred by WLAN completely without cables. Accessing the Internet and local network resources (e.g. printers) is now child's play when within range of an access point/hotspot.
Digital monitor output
Large TFT monitors work with extremely high resolutions. Digital technology is essential for displaying video signals in excellent quality and with no loss of performance. This Mini-PC offers a high-quality DVI monitor output.
Supports dual monitoring
For increased screen area the two monitor outputs (DVI+VGA) can be connected to one display each. Depending on the settings, the output image can be duplicated or expanded on the second screen.
HDMI interface
Goodbye cable spaghetti! Modern flat-screen TVs and large-format TFT screens can be connected to this Mini-PC with just a single thin cable. Often the audio output is also transferred in brilliant quality via the HDMI cable. If your Mini-PC already has a Blu-ray drive, the path to high-definition entertainment is clear.
Just 2.5" HDDs
An extremely compact PC housing offers less space for drives, that's why this Mini-PC uses slimline 2.5-inch hard disks. The advantage of this is that there's less noise, less heat generated and reduced power consumption. However small hard disks in a small housing does not have to mean less memory. Modern 2.5" HDDs are every bit as good as their 3.5" brothers.
Compatible with Microsoft Windows 7
This Shuttle Mini-PC is ideally prepared for the new Microsoft Windows 7 operating system. Updating to the new version couldn't be simpler.
Optimal air flow
Warm air is transported out of the chassis by means of cleverly arranged components, which enables a large number of parts to be cooled simultaneously in the air flow. At no time can heat build up and adversely affect the stability of the system.
Shuttle XS36VL - Atom D2550 1.86 GHz - 0 MB - 0 GB
PC barebone
Slim-PC
1 x Intel Atom D2550 / 1.86 GHz ( Dual-Core )
Processor Main Features
Hyper-Threading Technology
Cache Memory
1 MB L2 Cache
Cache Per Processor
1 MB
RAM
0 MB (installed) / 4 GB (max) - DDR3 SDRAM
Storage Controller
SATA ( SATA 3Gb/s )
Hard Drive
No HDD
Card Reader
Graphics Controller
Intel GMA 3650 Dynamic Video Memory Technology
Audio Output
Integrated - stereo
GigE, 802.11b, 802.11g, 802.11n
AC 120/230 V ( 50/60 Hz )
OS Provided
No operating system
22 cm x 16 cm x 3.6 cm
1.6 kg
PC barebone
Product Form Factor
Slim-PC
Processor / Chipset
CPU
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
Chipset Type
Intel NM10 Express
Cache Memory
Installed Size
L2 Cache - 1 MB
Cache Per Processor
1 MB
RAM
Installed Size
0 MB / 4 GB (max)
DDR3 SDRAM
SO DIMM 204-pin
Hard Drive
No HDD
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 3Gb/s
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card, SDHC Memory Card, SDXC Memory Card
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Max Allocated RAM Size
384 MB
Video Interfaces
VGA, DVI, HDMI
Audio Output
Integrated
Sound Output Mode
Stereo
Ethernet Controller
Realtek RTL8411
Wireless LAN Supported
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Wake on LAN (WoL)
Bays
1 (total) / 1 (free) x internal 2.5" x 1/8H
Slots
2 (total) / 2 (free) x SO DIMM 204-pin , PCIe Mini Card
1 x HDMI , 1 x VGA , 1 x DVI-D , 5 x USB 2.0 ( 1 front, 4 rear ) , 1 x LAN (Gigabit Ethernet) , 1 x microphone , 1 x audio line-out/headphones , 2 x serial ( 2 in front )
Security lock slot (cable lock sold separately), fanless
Mounting Interface
Plug and Play, ACPI 2.0, C-Tick, BSMI, CB, CCC, FCC, RoHS, ETL, Energy-using Products (EuP) Lot 6
Power adapter
Nominal Voltage
Power Provided
40 Watt
25 Watt
Power Consumption Stand by / Sleep
16 Watt
Operating System / Software
OS Provided
No operating system
22 cm
16 cm
3.6 cm
1.6 kg
35 °C
10 - 90% (non-condensing)
Resources
The following resources are available for the Shuttle XS36VL Intel Atom D2550 NM10 DDR3 Slim PC
