Click to visit BT.com
BT.com
Wishlist
Shuttle DS47 Ultra-Slim Fanless Media PC Celeron 847 DDR3
Quicklinx: 8WRXWS00
Mfr#: DS47
Full-Feature Fanless Media Player in an ultra-compact package
Shuttle's DS47 is an ultra-slim, energy-efficient, and full HD digital signage media player, built-in RS232/RS422/RS485, USB 2.0&3.0 and dual Gigabit-LAN dedicated interfaces, you can easily connect a variety of peripherals. The DS47 is equipped with Intel® high-performance Celeron dual-core processor, provides HDMI, DVI-I output interface, support dual display function; the exclusive integration of low-power design and fan-less cooling, body thickness of less than 40mm, only use 65W external power supply to keep system long time operation, and compared with traditional PC can also be reduced by nearly 40% noise. Customers can have lower energy consumption and reliable silent system for their digital signage solution.
Application: Digital Signage, POS (Point-of-Sales), KIOSK, Education, Medical, Automation, Office computers, thin client and call center
Support Full HD video format
Shuttle DS47 is equipped with Intel® high-performance Celeron 847 1.10 GHz dual-core processor, built-in Intel® HD Graphics, memory support up to DDR3-1333 16GB capacity, can play a variety of Full-HD/ 1080 P high definition video format content.
Multiple I/O interfaces
Shuttle DS47 built-in RS232/RS422/RS485 dedicated interface, four USB 2.0 ports at the front panel, and two USB3.0 ports at the rear panel can easily connect to peripherals such as thermal printer, label printer and bar code scanner. It offers a wide range of vertical applications.
VESA Mount Capability
The compact body of the DS47 has multiple screw holes specially designed on the side of the body. This design not only complies with international VESA Mount Standards, but also allows users to choose the most appropriate back hanging configuration and placement under different environments. This space saving capability is well-suited for application of digital signage with limited space.
24/7 nonstop operation
Shuttle DS47 is officially approved for 24/7 permanent operation. Thanks to Shuttle's low power consumption design and provide a stable operating environment, this PC runs highly reliable making it perfectly suitable for digital signage or other vertical applications.
Fanless Design
The DS47 uses ideal cooling thermal module with cooled heat pipes that can transmit heat to the whole cooling module quickly and evenly. It can be achieved high cooling efficiency without cooling fans. Combined with precisely vent design, the waste heat inside the computer can be moved out quickly.
Dual display support
The DS47 provides HDMI and DVI-I dual display output interfaces, built-in Intel® HD graphics, greatly upgrade digital signage display quality.
Dual Gigabit LAN high connectivity
The DS47 has built-in Realtek 8111G dual LAN, supports 10Mb/s, 100 Mb/s, 1000 Mb/s high-speed transfer capacity, and Wake On LAN function; built-in IEEE 802.11b/g/n wireless network card, the maximum transmission rate of up to 300 Mbps. It significantly enhances the digital signage system data transfer efficiency and save the operating time.
Energy-saving
The exclusive integration low-power design and fan-less cooling, the DS47 consumes only 65W of power in full use and can keep stable for long-time operation; Compared with traditional PCs, a nearly 40% noise reduction during the operation, it is particularly suited for noise sensitive environment such as hospitals and libraries.
Shuttle DS47 - Celeron 847 1.1 GHz - 0 MB - 0 GB
PC barebone - Slim-PC
1 x Intel Celeron 847 / 1.1 GHz ( Dual-Core )
Cache Memory
2 MB L3 Cache
Cache Per Processor
2 MB
RAM
0 MB (installed) / 16 GB (max) - DDR3 SDRAM - non-ECC
Storage Controller
SATA ( SATA 6Gb/s )
Hard Drive
No HDD
Card Reader
Graphics Controller
Intel HD Graphics
Audio Output
Stereo - integrated
GigE, 802.11b, 802.11g, 802.11n
AC 120/230 V ( 50/60 Hz )
OS Provided
No operating system
20 cm x 16.5 cm x 3.95 cm
1.43 kg
PC barebone
Product Form Factor
Slim-PC
Processor / Chipset
CPU
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
Chipset Type
Mobile Intel NM70 Express
Cache Memory
Installed Size
L3 Cache - 2 MB
Cache Per Processor
2 MB
RAM
Installed Size
0 MB / 16 GB (max)
SO-DIMM 204-pin
Unbuffered, dual channel memory architecture
Hard Drive
No HDD
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 6Gb/s
Channel Qty
1
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card, SDHC Memory Card, SDXC Memory Card
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Intel HD Graphics
Video Interfaces
DVI, HDMI
Max Monitors Supported
2
Audio Output
Integrated
Sound Output Mode
Stereo
High Definition Audio
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
Realtek RTL8111G
Wireless LAN Supported
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Wake on LAN (WoL), PXE support, Teaming support
Bays
1 (total) / 1 (free) x internal 2.5" x 1/6H
Slots
2 (total) / 2 (free) x SO-DIMM 204-pin , 1 (total) / 0 (free) x PCIe Half Mini Card , 1 (total) / 1 (free) x PCIe 2.0 Mini Card
1 x microphone - mini-jack , 1 x audio line-out/headphones - mini-jack , 1 x DVI-I , 1 x HDMI , 2 x LAN (Gigabit Ethernet) , 2 x USB 3.0 , 4 x USB 2.0 ( 4 in front ) , 2 x serial ( 2 in front )
Horizontal feet, VESA mounting kit
Fanless, UEFI BIOS
Theft/Intrusion Protection
Mounting Interface
100 x 100 mm, 75 x 75 mm
C-Tick, BSMI, CB, CCC, FCC, ETL, EMI, Directive 73/23/EWG, Directive 89/336/EWG
Power adapter
Nominal Voltage
Power Provided
65 Watt
21.8 Watt
Power Consumption Stand by / Sleep
12.9 Watt
Operating System / Software
OS Provided
No operating system
Software
Drivers & Utilities
20 cm
16.5 cm
3.95 cm
1.43 kg
35 °C
10 - 90% (non-condensing)
