BT.com
Wishlist
Sharp PNY325 32"  1920x1080 USB LED LFD
Sharp PNY325 32" 1920x1080 USB LED...
£635.14
£635.14
Add to wishlist
Delivery
Standard Due date unavailable
Sharp's multi-purpose, user-friendly PN-Y325 LED display delivers your message with the eye-catching impact of Full HD resolution. Sized to match a wide variety of installation locations, this professional monitor performs equally well in public areas, offices, and retail spaces, whether in a landscape or a portrait orientation. A built-in USB media player supports playback of both still images and videos and allows the PN-Y325 to be used as a standalone signage solution even in the absence of a PC or network connection.
Sharp PN-Y325 PN-Y Series - 32" LED display
LED-backlit LCD flat panel display
Diagonal Class
32"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
Component, composite, HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
UV²A
LCD Backlight Technology
LED backlight - edge-lit
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
USB
Voltage
56 Watt
75 cm x 4.8 cm x 44.4 cm
8.5 kg
56 Watt
Diagonal Class
32"
Commercial Use
Series
PN-Y Series
TV Tuner
No tuner
Video Interface
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Modes
Portrait mode, landscape mode, Mirror Display Mode
Design
Slim Bezel Design
Cooling System
Fanless
Dimensions
Without stand
75 cm
4.8 cm
44.4 cm
8.5 kg
Enclosure Colour
Display
LCD Display Technology
UV²A
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Colour Depth
16.7 million colours
Image Contrast Ratio
3000:1
Brightness
350 cd/m²
Viewing Angle
178°
Viewing Angle (Vertical)
178°
Response Time
8 ms
Certified for 24/7 Continuous Operation
Stands & Mounts
Flat Panel Mount Interface
200 x 200 mm
Media Player
USB Port
USB Ports Qty
1
Audio System
Speaker System
2 speakers
Output Power / Total
10 Watt
Speakers
2 x main channel speaker - built-in - 5 Watt
Connector Type
HDMI input - rear , DVI-D input - rear , DVI-D output - rear , Network - rear , Component video / composite video / VGA input - rear , USB - rear , Serial input - rear , Serial output - rear , Audio line-in - rear , Audio line-in - rear , Audio line-out - rear
Plug and Play
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
On / Off Switch
20 - 80%
Scroll to top
