BT.com
Wishlist
Sharp PNV602 60" 1366x768 DVI HDMI LED Large Format Display
Sharp PNV602 60" 1366x768 DVI HDMI...
£6,494.11
£6,494.11
Add to wishlist
Delivery
Standard Due date unavailable
The PN-V602 video wall monitor combines the slimmest bezel available on a 60" class LCD monitor with high brightness for semi-outdoor environments. With 24/7 reliability and an almost seamless bezel, the PN-V602 sets a standard for video wall displays. A full-array LED backlight helps ensure uniform brightness. Local dimming also helps deliver a remarkably better contrast ratio and brightness compared to conventional LCD monitors, while utilizing significantly less power.
Sharp PN-V602 PN-V Series - 60" LED display
LED-backlit LCD flat panel display
Diagonal Class
60"
Commercial Use
Yes - digital signage
Resolution
1366 x 768
Display Format
720p
Video Wall Components Qty
25
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
VGA (HD-15)
UV²A
LCD Backlight Technology
LED backlight - local dimming
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Hardware Diagnosis
Voltage
510 Watt
133.59 cm x 14.93 cm x 75.42 cm
45 kg
3 years warranty
510 Watt
Diagonal Class
60"
Commercial Use
Series
PN-V Series
TV Tuner
No tuner
Sensors
Brightness sensor
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
VGA (HD-15)
Modes
Portrait mode, landscape mode, Mirror Display Mode
25
Dimensions
Without stand
133.59 cm
14.93 cm
75.42 cm
45 kg
Display
LCD Display Technology
UV²A
Resolution
1366 x 768
Display Format
720p
Image Aspect Ratio
16:9
Image Contrast Ratio
5000:1
Dynamic Contrast Ratio
1000000:1
Brightness
1500 cd/m²
Viewing Angle
176 degrees
Viewing Angle (Vertical)
176 degrees
Response Time
6 ms
Backlight Life
50000 hour(s)
Commercial Features
Hardware Diagnosis
Certified for 24/7 Continuous Operation, Bezel Correction
Stands & Mounts
Flat Panel Mount Interface
200 x 200 mm
Connector Type
HDMI input , VGA input , Audio line-in , Serial input , Serial output , Audio line-out
Plug and Play, GOST, CB
Power supply
Nominal Voltage
Limited warranty - 3 years
20 - 80%
Scroll to top
