BT.com
Wishlist
Sharp PNV601(A) 60" 1366x768 HDMI LED Large Format Display
Sharp PNV601(A) 60" 1366x768 HDMI...
£5,386.56
£5,386.56
Add to wishlist
Delivery
Standard Due date unavailable
The PN-V601A ultra thin bezel model is mainly designed for video wall applications. This 152 cm (60") LCD-monitor can be used in a variety of signage and multi screen configurations. As a flexible solution with an almost seamless bezel, the PN-V601A sets a new standard for video wall displays.
Sharp PN-V601A PN-V Series - 60" LED display
LED-backlit LCD flat panel display
Diagonal Class
60"
Commercial Use
Yes - digital signage
Resolution
1366 x 768
Display Format
720p
Video Wall Components Qty
25
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight - direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Voltage
480 Watt
133.59 cm x 14.93 cm x 75.42 cm
45 kg
480 Watt
Diagonal Class
60"
Commercial Use
Series
PN-V Series
TV Tuner
No tuner
Sensors
Brightness sensor
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
VGA (HD-15)
HDCP Compatible
Modes
Portrait mode, landscape mode, Mirror Display Mode
25
Dimensions
Without stand
133.59 cm
14.93 cm
75.42 cm
45 kg
Display
Resolution
1366 x 768
Display Format
720p
Image Aspect Ratio
16:9
Colour Depth
16.7 million colours
Image Contrast Ratio
4000:1
Brightness
700 cd/m²
Viewing Angle
176 degrees
Viewing Angle (Vertical)
176 degrees
Response Time
6 ms
Certified for 24/7 Continuous Operation, Hardware Diagnostics, Bezel Correction
Stands & Mounts
Flat Panel Mount Interface
200 x 200 mm
Connector Type
HDMI input - rear , VGA input - rear , Audio line-in - rear , Audio line-out - rear , Serial input - rear , Serial output - rear , Remote control - rear
Plug and Play
Power supply
Nominal Voltage
On / Off Switch
20 - 80%
Scroll to top
