BT.com
Wishlist
Sharp PNV600(A) 60" 1366x768 HDMI LED Large Format Display
Sharp PNV600(A) 60" 1366x768 HDMI...
£4,489.41
£4,489.41
Add to wishlist
Delivery
Standard Due date unavailable
Designed for sophisticated video wall applications, the PN-V600A video wall monitor offers the world's slimmest bezel available on a 60" class (60" diagonal) LCD display. As a flexible digital signage solution with 24/7 certified reliability and an almost seamless bezel (just 6.5 mm total between neighboring monitors), the PN-V600A helps set a great standard for video wall displays. Its full-array LED backlight helps ensure uniform brightness and an enlarge (zoom) display mode enables one image to be expanded across up to 25 monitors (in a 5x5 configuration). An optional PN-ZR01 Control Kit permits all monitors in a video wall to be operated using a single remote.
Sharp PN-V600A PN-V Series - 60" LED display
LED-backlit LCD flat panel display
Diagonal Class
60"
Commercial Use
Yes - digital signage
Resolution
1366 x 768
Display Format
720p
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
VGA (HD-15)
HDCP Compatible
UV²A
LCD Backlight Technology
LED backlight - direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Voltage
310 Watt
133.59 cm x 14.93 cm x 75.42 cm
41 kg
310 Watt
Diagonal Class
60"
Commercial Use
Series
PN-V Series
TV Tuner
No tuner
Sensors
Brightness sensor
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
VGA (HD-15)
HDCP Compatible
Modes
Portrait mode, landscape mode, Mirror Display Mode
Dimensions
Without stand
133.59 cm
14.93 cm
75.42 cm
41 kg
Display
LCD Display Technology
UV²A
Resolution
1366 x 768
Display Format
720p
Image Aspect Ratio
16:9
Colour Depth
16.7 million colours
Image Contrast Ratio
4000:1
Brightness
450 cd/m²
Viewing Angle
176 degrees
Viewing Angle (Vertical)
176 degrees
Response Time
6 ms
Certified for 24/7 Continuous Operation, Hardware Diagnostics, Bezel Correction
Stands & Mounts
Flat Panel Mount Interface
200 x 200 mm
Connector Type
HDMI input - rear , VGA input - rear , Audio line-in - rear , Audio line-out - rear , Serial input - rear , Serial output - rear , Remote control - rear
Plug and Play
Power supply
Nominal Voltage
Power Consumption Stand by
1 Watt
On / Off Switch
20 - 80%
Scroll to top
