BT.com
Wishlist
Sharp PNU553 55" 1920x1080 DVI HDMI DisplayPort LED Large Format Display
Sharp PNU553 55" 1920x1080 DVI HDMI...
£2,141.77
£2,141.77
Add to wishlist
Delivery
Standard Due date unavailable
A brightness of 700 cd/m2 PN-U553 supports these LCD monitors in their digital signage duties. And PN-U553 monitors boast 1,920 (H) x 1,080 (V)-pixel full-HD resolution to ensure that none of the detail or visual impact is lost. Thanks to Full-HD resolution, everything from fine text to intricate graphics is stunningly crisp and clear.
PN-U553 monitor owes its exceptionally thin profiles to edge-lit LED backlighting, where LED elements are located at the edges of the panel. The stylishly thin profiles also enable attractive wall mounting.
Sharp PN-U553 PN series - 55" LED display
LED-backlit LCD flat panel display
Diagonal Class
55"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
480p, 720p, 1080i, 1080p, 480i, 576i, 576p, 1080/24p
Video Interface
Component, HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
UV²A
LCD Backlight Technology
LED backlight - edge-lit
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Voltage
AC 120/230 V
130 Watt
125 cm x 5.7 cm x 72.1 cm
25 kg
130 Watt
Diagonal Class
55"
Commercial Use
Series
PN series
TV Tuner
No tuner
Video Interface
Component, HDMI
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
Modes
Portrait mode, landscape mode
Dimensions
Without stand
125 cm
5.7 cm
72.1 cm
25 kg
Display
LCD Display Technology
UV²A
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Colour Depth
Up to 1.06 billion colours
Image Contrast Ratio
4000:1
Brightness
700 cd/m²
Viewing Angle
178°
Viewing Angle (Vertical)
178°
Response Time
6.5 ms
Split screen, Certified for 24/7 Continuous Operation, Ultraviolet-induced Multi-domain Vertical Alignment technology (UV2A), Data Signal Power Auto (DSPA)
Stands & Mounts
Flat Panel Mount Interface
200 x 400 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1024 x 768 (XGA), 800 x 600 (SVGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 1280 x 800, 1400 x 1050
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Connector Type
Serial input , Network , HDMI input , DisplayPort input , DVI-D input , DVI-D output , VGA / component video input , Audio line-in , Component video input , Audio line-in , Audio line-out
Power supply
Nominal Voltage
AC 120/230 V
Power Consumption Stand by
4.5 Watt
Scroll to top
