BT.com
Wishlist
Sharp PNU473 47" 1920x1080 DVI HDMI DisplayPort LED Large Format Display
Delivery
Standard Due date unavailable
Sharp's PN-U473 professional LED display clearly has what it takes to get your message across. Designed for maximum impact, built for 24/7 durability, and sized for flexible installation, this 47 inch class display represent a dynamic indoor digital signage solution. Thin and lightweight enough to ensure an easy fit in stores, offices, and public spaces, the PN-U473 display boasts the outstanding image quality needed to deliver truly compelling signage.
Sharp PN-U473 PN series - 47" LED display
LED-backlit LCD flat panel display
Diagonal Class
47"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
Component, composite, HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, DisplayPort
HDCP Compatible
LCD Backlight Technology
LED backlight - edge-lit
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Voltage
130 Watt
108.3 cm x 5.5 cm x 62.7 cm
19 kg
130 Watt
Diagonal Class
47"
Commercial Use
Series
PN series
TV Tuner
No tuner
Video Interface
HDMI Ports Qty
1 ports
PC Interface
DVI, DisplayPort
HDCP Compatible
Modes
Portrait mode, landscape mode, Mirror Display Mode
Dimensions
Without stand
108.3 cm
5.5 cm
62.7 cm
19 kg
Enclosure Colour
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Colour Depth
Up to 1.06 billion colours
Image Contrast Ratio
1300:1
Brightness
700 cd/m²
Viewing Angle
178°
Viewing Angle (Vertical)
178°
Response Time
12 ms
Certified for 24/7 Continuous Operation
Stands & Mounts
Flat Panel Mount Interface
400 x 200 mm
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Connector Type
DVI-D input ¦ HDMI input ¦ Component video input ¦ DisplayPort input ¦ Composite video input ¦ DVI-D output ¦ Audio line-in ¦ Network ¦ Audio line-out ¦ Serial input ¦ Serial output
Plug and Play
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
20 - 80%
Scroll to top
