BT.com
Wishlist
Sharp PNR903 90" 1920x1080 DVI HDMI DisplayPort LED Large Format Display
Sharp PNR903 90" 1920x1080 DVI HDMI...
£12,705.88
£12,705.88
Add to wishlist
Delivery
Standard Due date unavailable
Go big! With its magnificent 90" class diagonal screen size, 24/7 reliability and energy efficient full-array LED backlight, the PN-R903 is designed to meet the rigors of most any commercial display or digital signage application while captivating your audience. Add to this Sharp's UV2A photo alignment technology, local dimming technology, full 1920 x 1080 HD resolution, you have one of the largest, highest performing and most flexible displays in the industry. For versatility, performance and value, there's never been a better time to think big - and think Sharp.
Sharp PN-R903 90" LED display
LED-backlit LCD flat panel display
Diagonal Class
90"
Commercial Use
Yes - digital signage
Country Kits
Europe
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
480p, 720p, 1080i, 1080p, 480i, 540p, 1035i, 576i, 576p, 1080/24p
Video Interface
HDMI
LAN
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight - full array, local dimming
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
AC 120/230 V
Energy Class
Class A
660 Watt
205.5 cm x 12.2 cm x 119.7 cm
75 kg
Energy Class
Class A
660 Watt
Diagonal Class
90"
Commercial Use
TV Tuner
No tuner
Video Interface
HDMI
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Modes
Portrait mode, landscape mode
Dimensions
Without stand
205.5 cm
12.2 cm
119.7 cm
75 kg
Country Kits
Europe
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Colour Depth
Up to 1.06 billion colours
Image Contrast Ratio
4000:1
Dynamic Contrast Ratio
1000000:1
Brightness
700 cd/m²
Viewing Angle
176 degrees
Viewing Angle (Vertical)
176 degrees
Response Time
6 ms
Split screen, Certified for 24/7 Continuous Operation, UV 2 A technology
Stands & Mounts
Flat Panel Mount Interface
600 x 400 mm, 600 x 600 mm
Video Features
Analogue Video Input Signals
PAL, SECAM, NTSC 3.58, NTSC4.43, PAL-M, PAL-N, PAL60
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1024 x 768 (XGA), 800 x 600 (SVGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 1280 x 800, 1400 x 1050
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
LAN
Connector Type
DVI-I , DVI-D output , HDMI , VGA input , Serial , Network , Audio line-in , Audio line-out
Power supply
Nominal Voltage
AC 120/230 V
Power Consumption Stand by
0.5 Watt
Scroll to top
