BT.com
Wishlist
Sharp PNR603 60" 1920x1080 DVI HDMI DisplayPort LED Large Format Display
Sharp PNR603 60" 1920x1080 DVI HDMI...
£3,000.00
£3,000.00
Add to wishlist
Delivery
Standard Due date unavailable
With its 60" class diagonal screen size, 24/7 reliability and energy efficient edge lit LED backlight, the PN-R603 is designed to meet the rigors of most any commercial display or digital signage application. Add to this Sharp's UV2A photo alignment technology, full 1920 x 1080 HD resolution, and optional media player, you have one of the highest performing and most flexible displays in the industry. For versatility, performance and value, there's never been a better time to think BIG - and think Sharp.
Sharp PN-R603 60" LED display
LED-backlit LCD flat panel display
Diagonal Class
60"
Commercial Use
Yes - digital signage
Country Kits
Europe
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
480p, 720p, 1080i, 1080p, 480i, 540p, 1035i, 576i, 576p, 1080/24p
Video Interface
HDMI
LAN
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight - edge-lit
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Voltage
AC 120/230 V
Energy Class
Class A
200 Watt
137.8 cm x 3.94 cm x 79.4 cm
32 kg
Energy Class
Class A
200 Watt
Diagonal Class
60"
Commercial Use
TV Tuner
No tuner
Video Interface
HDMI
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Modes
Portrait mode, landscape mode
Dimensions
Without stand
137.8 cm
3.94 cm
79.4 cm
32 kg
Country Kits
Europe
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Colour Depth
Up to 1.06 billion colours
Image Contrast Ratio
4000:1
Brightness
700 cd/m²
Viewing Angle
176 degrees
Viewing Angle (Vertical)
176 degrees
Response Time
6 ms
Split screen, Certified for 24/7 Continuous Operation
Stands & Mounts
Flat Panel Mount Interface
Video Features
Analogue Video Input Signals
PAL, SECAM, NTSC 3.58, NTSC4.43, PAL-M, PAL-N, PAL60
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1024 x 768 (XGA), 800 x 600 (SVGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 1280 x 800, 1400 x 1050
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
LAN
Connector Type
DVI-D input , DVI-D output , HDMI , VGA input , Serial , Network , Audio line-in , Audio line-out
Power supply
Nominal Voltage
AC 120/230 V
Power Consumption Stand by
0.5 Watt
Scroll to top
