BT.com
Wishlist
Sharp PNA601 60" 1920x1080 DVI HDMI LED Large Format Display
Sharp PNA601 60" 1920x1080 DVI HDMI...
£6,515.29
Hurry, only 1 left in stock!
£6,515.29
Add to wishlist
Delivery
Standard 1-3 working days
For compelling digital signage in shopping malls, transportation hubs, college campuses and sports and entertainment facilities, the Sharp PN-A601 is a smart choice. This 60" class LED-LCD monitor offers ultra-high brightness for superb visibility, even in brightly lit window-facing indoor settings. The PN-A601 also provides exceptionally high image quality in full 1080p HD, with the energy savings efficiency of a full-array LED backlight in combination with local dimming.
Sharp PN-A601 PN-A Series - 60" LED display
LED-backlit LCD flat panel display
Diagonal Class
60"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
480p, 720p, 1080i, 1080p, 480i, 540p, 1035i, 576i, 576p, 1080/24p
Video Wall Components Qty
25
Video Interface
Component, composite, HDMI
HDMI Ports Qty
1 ports
PC Interface
VGA (HD-15)
HDCP Compatible
UV²A
LCD Backlight Technology
LED backlight - local dimming
Image Aspect Ratio
16:9
TV Tuner
No tuner
Remote Control
Standard remote
Voltage
AC 120/230 V
Energy Class
Class C
620 Watt
Power Consumption (On mode)
260 W
137.4 cm x 11.2 cm x 79.3 cm
45 kg
Energy Class
Class C
620 Watt
260 W
Diagonal Class
60"
Commercial Use
Series
PN-A Series
TV Tuner
No tuner
Video Interface
HDMI Ports Qty
1 ports
PC Interface
VGA (HD-15)
HDCP Compatible
Modes
Portrait mode, landscape mode
25
Dimensions
Without stand
137.4 cm
11.2 cm
79.3 cm
45 kg
Display
LCD Display Technology
UV²A
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Colour Depth
16.8 million colours
Image Contrast Ratio
5000:1
Brightness
2000 cd/m²
Viewing Angle
176 degrees
Viewing Angle (Vertical)
176 degrees
Response Time
6 ms
Certified for 24/7 Continuous Operation, Data Signal Power Auto (DSPA)
Stands & Mounts
Flat Panel Mount Interface
200 x 200 mm, 400 x 200 mm
Video Features
Analogue Video Input Signals
SECAM, NTSC 3.58, NTSC4.43, PAL-M, PAL-N, PAL60
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1024 x 768 (XGA), 800 x 600 (SVGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 1280 x 800, 1400 x 1050
Remote Control
Standard remote
Connector Type
HDMI input - rear , Component video / composite video / VGA input - rear , Audio line-in - rear , Audio line-out - rear , Serial input - rear , Serial output - rear , Remote control - rear
VGA cable
EMC Class A
Power supply
Nominal Voltage
AC 120/230 V
Power Consumption Stand by
1 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
Scroll to top
