BT.com
Wishlist
Sharp PN80TC3 80" 1920x1080 LED LFD
Sharp PN80TC3 80" 1920x1080 LED...
£10,835.29
Hurry, only 3 left in stock!
£10,835.29
Add to wishlist
Delivery
Standard 1-3 working days
Say goodbye to unintended input and writing errors. Thanks to the PN-80TC3's precise position detection, only intentional input from fingers and touch pens appears on the display. Employing Sharp's original capacitive touch technology - which achieves high sensitivity and precision by reducing the noise level - the PN-80TC3 eliminates unwanted noise to deliver a clear onscreen signal. The PN-80TC3 lets you capture ideas at the moment of creation. Recognizing up to 10 touch points, it allows up to four people to write at the same time with a finger or touch pen.
Sharp BIG PAD PN-80TC3 80" LED display
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
80"
Commercial Use
Yes - interactive communication
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
Component, composite, HDMI
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15), DisplayPort
HDCP Compatible
UV²A
LCD Backlight Technology
LED backlight
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Voltage
280 Watt
185 cm x 9.6 cm x 107.2 cm
77 kg
280 Watt
Diagonal Class
80"
Commercial Use
Combined with
Touchscreen
TV Tuner
No tuner
Video Interface
HDMI Ports Qty
3 ports
PC Interface
HDCP Compatible
Modes
Whiteboard mode
Protection
Protection glass
Dimensions
Without stand
185 cm
9.6 cm
107.2 cm
77 kg
Display
LCD Display Technology
UV²A
Resolution
1920 x 1080
Display Format
1080p (Full HD)
LED backlight
Colour Depth
Up to 1.06 billion colours
Image Contrast Ratio
4000:1
Brightness
300 cd/m²
Viewing Angle
176 degrees
Viewing Angle (Vertical)
176 degrees
Pixel Pitch
0.923 x 0.923 mm
Touchpoints Qty
10
Response Time
4 ms
Infrared blocking detection, handwriting recognition
Stands & Mounts
Flat Panel Mount Interface
600 x 400 mm
Video Features
Analogue Video Input Signals
PAL, SECAM, NTSC 3.58, NTSC4.43, PAL60
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Connector Type
USB 2.0 , VGA input , 3 x HDMI input , 2 x audio line-in , Component video input , Composite video input , 2 x audio line-in , DisplayPort input , Serial input , DisplayPort output , Audio line-out , Speakers output
2 AAA batteries, 2 AA batteries, eraser, Sharp Pen Software, pen tray, blank sticker, electronic touch pen, touch pen adapter, 7 x cable clamps
Plug and Play, DDC-2B
Power supply
Nominal Voltage
5 °C
35 °C
20 - 80% (non-condensing)
Scroll to top
