BT.com
Wishlist
Sharp PN60TB3 60" 1920x1080 VGA DVI HDMI DP LCD LFD
Sharp PN60TB3 60" 1920x1080 VGA DVI...
£4,525.39
£4,525.39
Add to wishlist
Delivery
Standard Due date unavailable
Sharp's BIG PAD interactive touch screen monitor PN-60TB3 is designed for smooth and effortless communication in a wide range of contexts. The highly responsive touch pen technology allows several people to write on the same screen at the same time.
Sharp BIG PAD PN-60TB3 60" Class (60.06" viewable) LED display
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
60"
Diagonal Size
60.06 in
Commercial Use
Yes - interactive communication
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
1080p
Video Interface
HDMI
HDMI Ports Qty
3 ports
LAN
PC Interface
VGA (HD-15), DisplayPort
HDCP Compatible
UV²A
LCD Backlight Technology
LED backlight - edge-lit
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Voltage
185 Watt
143.7 cm x 9.4 cm x 89 cm
46 kg
185 Watt
Diagonal Class
60"
Diagonal Size
60.06 in
Commercial Use
Combined with
Touchscreen
TV Tuner
No tuner
Video Interface
HDMI
HDMI Ports Qty
3 ports
PC Interface
HDCP Compatible
Modes
Landscape mode
Design
Fanless Design
Dimensions
Without stand
143.7 cm
9.4 cm
89 cm
46 kg
Enclosure Colour
Display
LCD Display Technology
UV²A
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Coating
Anti-glare
Colour Depth
Up to 1.06 billion colours
Image Contrast Ratio
3000:1
Brightness
300 cd/m²
Viewing Angle
160 degrees
Viewing Angle (Vertical)
160 degrees
Pixel Pitch
0.692 x 0.692mm
Touchpoints Qty
10
Response Time
6 ms
Certified for 24/7 Continuous Operation, Quick Start, infrared blocking detection, Touch Display Link 2.0 software
Stands & Mounts
Flat Panel Mount Interface
400 x 200 mm
Video Features
Analogue Video Input Signals
PAL, SECAM, NTSC 3.58, NTSC4.43, PAL60
Input Video Formats
1080p
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
LAN
LAN Protocol
Ethernet
Connect & Share
USB Human Interface Device (HID)
Connector Type
USB 2.0 - side , VGA input - side , 2 x HDMI input - side , Audio line-in - side , Speakers output - bottom , Audio line-out - bottom , DisplayPort output - bottom , USB - bottom , USB 2.0 - bottom , LAN - bottom , VGA input - bottom , DisplayPort input - bottom , HDMI input - bottom , Audio line-in - bottom
2 AA batteries, eraser, camera mounting kit, pen tray, blank sticker, electronic touch pen, 5 x cable clamps
USB cable - 3 m
Plug and Play, DDC-2B, VESA DPMS
Power supply
Nominal Voltage
5 °C
35 °C
20 - 80% (non-condensing)
Scroll to top
