BT.com
Wishlist
Sharp PN-E703 70" 1920x1080 LED LFD
Sharp PN-E703 70" 1920x1080 LED...
£3,792.07
Hurry, only 1 left in stock!
£3,792.07
Add to wishlist
Delivery
Standard 1-3 working days
These 70-inch-class (69.5" diagonal) Sharp monitos combines Full-HD image quality, stylishly thin profiles and energy efficiency to create appealing professional signage solutions for a wide range of applications. With their sleek design, around-the-clock operation, and support for landscape and portrait installations, this display offers an amazing degree of flexibility. In hotel lobbies, conference rooms, retail spaces and elsewhere, the PN-E703 will grab and keep the attention of your target audience.
Sharp PN-E703 70" Class (69.5" viewable) LED display
LED-backlit LCD flat panel display
Diagonal Class
70"
Diagonal Size
69.5 in
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
HDMI
HDMI Ports Qty
2 ports
LAN
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
UV²A
LCD Backlight Technology
LED backlight - edge-lit
TV Tuner
No tuner
Speaker System
2 speakers
Voltage
225 Watt
157.8 cm x 3.94 cm x 91.6 cm
43 kg
3 years warranty
225 Watt
Diagonal Class
70"
Diagonal Size
69.5 in
Commercial Use
TV Tuner
No tuner
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
HDCP Compatible
Modes
Portrait mode, landscape mode, Mirror Display Mode
Dimensions
Without stand
157.8 cm
3.94 cm
91.6 cm
43 kg
Display
LCD Display Technology
UV²A
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Colour Depth
Up to 1.06 billion colours
Image Contrast Ratio
4000:1
Brightness
450 cd/m²
Viewing Angle
176 degrees
Viewing Angle (Vertical)
176 degrees
Pixel Pitch
0.802 x 0.802mm
Response Time
6 ms
Certified for 24/7 Continuous Operation, sync on green
Stands & Mounts
Flat Panel Mount Interface
200 x 200 mm
Video Features
Analogue Video Input Signals
PAL, SECAM, NTSC 3.58, NTSC4.43, PAL60
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
LAN
Connector Type
DisplayPort input - bottom , DisplayPort output - bottom , DVI-I input - bottom , DVI-D output - bottom , 2 x audio line-in - bottom , 2 x HDMI input - side , VGA input - side , Audio line-out - side , Serial input - side , Serial output - side , Network - side
Plug and Play, DDC-2B, DVI DMPM, VESA DPMS
Power supply
Nominal Voltage
Limited warranty - 3 years - on-site
20 - 80% (non-condensing)
Scroll to top
